What parts are most likely to break while off roading?
Discussion in '5th Gen 4Runners (2010-2024)' started by Ctreg, Oct 18, 2023.
  1. Oct 18, 2023 at 6:16 PM
    Ctreg
    Ctreg [OP] New Member
    Was wondering what parts might be the most likely to fail during an off road adventure? Also might anyone be able to put a cost on having them fixed or diy replacing them yourself? Like how much would a broken tie rod, wheel bearing, or ball joint cost to have a shop do it vs at home diy replacement?
    Banshee likes this.
  2. Oct 18, 2023 at 6:25 PM
    Startrek
    Startrek New Member
    transmission
  3. Oct 18, 2023 at 6:30 PM
    Tie rods, hub bearings, front CV axles, and ball joints are all susceptible to damage with hard wheeling. I don't think any of these are particularly expensive if you DIY, but you'd want to get an alignment after replacing a tie rod.
    kmeeg, ChessGuy and djwantke like this.
  4. Oct 18, 2023 at 6:30 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I know a pretty good answer to this. Replaced everything but bearings. Bought a ball joint separator tool, and sealed boot replacement kit in place of zerk balljoints. And bought a large Crowsfoot socket for tie rods (I replaced outer tie rods, and inner tie rods & bellows. Give me a moment to find my pricing
  5. Oct 18, 2023 at 6:33 PM
    @Thatbassguy mighty fine advice
    You think if you keep upper control arms and knuckle supported, and maybe mark up the previous adjustments with chalk, that you dont require alignment after ball joint swap?
  6. Oct 18, 2023 at 6:38 PM
    I don't really know. I just meant that you'd want an alignment after a tie rod swap.
    I've heard of people doing their own alignment successfully. It sounds too tedious to be worth the money to me, though. I don't think they're generally all that expensive.
  7. Oct 18, 2023 at 6:39 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Predator steps
  8. Oct 18, 2023 at 6:45 PM
    I thought our transmissions were pretty notorious for being bulletproof. Have you heard of anyone's A750 failing on a trail?
    nimby likes this.
  9. Oct 18, 2023 at 7:50 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Bodywork, I ripped off part of the silver rear valance a couple weeks ago lol
    OverRunner and Thatbassguy like this.
  10. Oct 18, 2023 at 8:10 PM
    Wiring. Over the years I've seen branches break wheel speed sensor wires on two vehicles, transfer case actuator wires, rear locker wires, and oil level switch wire (3rd gen Tacoma).
    Spare parts I recommend carrying:
    Serpentine belt, front and rear brake hoses, inner tie rod and boot, general wiring repair kit (fuses, butt & ring connectors, wires, heat shrink), rear ABS wire (can be cut down and spliced into any corner), headlight bulb if halogen, wiper blades, spare engine air filter for mud pits, spare hoses of various sizes seen under the hood and hose clamps, jump pack.
    Depending on duration of trip, wheel bearing may not be necessary - if it starts groaning during the trip, you can still drive home.
    Haven't seen a ball joint separate on the trail with 5th gens. Likewise with U-joints. IMO if you check these things at home and fix if you see grease leak or slop, they won't fail on the trail.
    The 2UZ V8 has a low-hanging alternator that likes to be caked in mud and fail. But that isn't a concern on the 5th gen.
    Old Tanker likes this.
  11. Oct 18, 2023 at 9:05 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    This. Rear silver valance part is about $500 from Toyota.
    Front bumper cover, both the silver part, and the lowest portions that are in front of the tires are also likely to suffer trail damage.
    Muffler and exhaust pipe are easy to nail.
    OEM skids can get dinged up, but that's what they are there for.
    Factory running boards.
  12. Oct 19, 2023 at 5:39 AM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    I managed to find a silver rear valance off marketplace for $30 luckily.
    bassist[QUOTED] and Thatbassguy like this.
  13. Oct 19, 2023 at 8:04 AM
    I think it’s Trolling?
  14. Oct 19, 2023 at 8:07 AM
    You’d have to really be abusing it to break stuff. Only parts I’ve seen fall off watching YouTube are the front and rear bumper facials.
  15. Oct 19, 2023 at 8:22 AM
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    OP, are you trying to weigh the cost/benefits of offroading whilst owning a 4runner?
  16. Oct 19, 2023 at 8:24 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    The things that will break while off roading will be whatever you forgot to bring that day to fix it. That’s always been my experience.
    Old Tanker and Trail Runnah like this.
  17. Oct 19, 2023 at 9:12 AM
    Ctreg
    Yes, also wondering how hard can I go lol. Wanted to get an idea of what kind of costs I would be looking at when I break something and what a worst case scenario might me in "going hard"? Parts aren't the problem right now it would seem it's availability and paying for labor that is stupid expensive right now.
  18. Oct 19, 2023 at 9:23 AM
    2018 Limited
    BDR
    2018 Limited
    I recently took my can am 850 north edition on a brutal ride with boulders, mud, downed trees and logs. In a blink of an eye $1500 worth of damage. That was just plastic and a headlamp. Everything is too expensive these days and nothing is in stock.
  19. Oct 19, 2023 at 9:29 AM
    Ctreg
    True, global supply chain is weak.
  20. Oct 19, 2023 at 9:48 AM
    bassist
    bassist New Member
    Let's be honest.
    You aren't going to be able to keep up with a comparably equipped Wrangler with an equally skilled driver off-road when it comes to rock crawling type situations. You will be the first one to break something when everyone is equally matched.
    When it goes to running at higher speeds out in the desert, you'll probably pull away without too much effort.
    At the end of the day, you'll have the more pleasant ride home. Especially since you won't have ducks flying everywhere whenever you accelerate or brake really hard.
    All that being said, the sky's the limit with what you can break - it's a question of how aggressive or conservative you are. Play the game right and you break nothing. Play it wrong and you end up like this...
    Bodie the Dog likes this.
  21. Oct 19, 2023 at 12:43 PM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    Your wallet will break first.
    2018 Limited likes this.
  22. Oct 19, 2023 at 1:31 PM
    Ctreg
    No... Supposed to say you'll be fine nothing can break ever lol.
  23. Oct 19, 2023 at 2:10 PM
    backpacker
    2023 TRD ORP
    A lot of unhappy endings start with bucking.
    bassist[QUOTED] and McSpazatron like this.
  24. Oct 19, 2023 at 2:12 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    Honestly? Your stock tires are the first to go. Then your rocker panels will take a beating.
    Cheers
  25. Oct 19, 2023 at 3:13 PM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Trail repairs I've done on other people's 5Gen rigs that had to get fixed on trail:
    Upper and lower ball joints
    Outter Tie rod end
    Passenger axle
    U-joint
    Abs Wires and sensor (especially in snow in the front)
    One front driver brake hose
    Rim gouge on OR aluminum rim
    Valve stem rip out
    Hubs will not typically grenade
    Alot of other things you can limp it back and get it home. Even a blown out axle can usually be nursed off the trail but can get weird when the cv boot tears out and the axle can do interesting things without the boot holding it together (depending on how it broke).
    I keep an upper ball joint, a lower ball joint, a brake hose and fittings that will work for front or rear, a universal split cv boot just for getting home, a good spare tire, Schrader valves, outter Tie rod end and cold beers!
  26. Oct 19, 2023 at 3:25 PM
    Bodie the Dog
    Bodie the Dog Danger Ranger!
    2016 TEP, 1994 SR5
    Shrockworks sliders & rear bumper, Toytec 3/2 lift, ARB diff mod, 8 pod RGB LED's, RCI steel front skids, Big Sky katana rack, Reese roof rack, cool stickers.
    You're welcome to run the trails with me anytime! Because I'm more like duct tape and bailing wire level, lol.
    MyWyfsRnnr[QUOTED] likes this.
  27. Oct 19, 2023 at 3:26 PM
    nova
    nova New Member
    mike
    Some of these lists are exhaustive and appropriate, depending on what the “adventure” entails.
    If you’re just starting out, keep it simple! Go out and have some fun with your friends.
    Let your version of adventure be your guide to preparedness. I think you’ll have more fun that way.
    Cheers
    McSpazatron and Bodie the Dog like this.
  28. Oct 19, 2023 at 3:41 PM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    I always have the family with me so getting stuck overnight is not typically an option haha! All that said, I have only had the abs wire in the snow issue so far. I don't push hard enough to break things unless everything has gone really sideways
    Bodie the Dog[QUOTED] likes this.
  29. Oct 19, 2023 at 3:42 PM
    I'd get recover gear first before you start carrying extra parts. Straps, jack and traction boards if you're on mud or sand.
    McSpazatron likes this.
  30. Oct 19, 2023 at 5:06 PM
    :laugh:
    If you don’t have extra money, don’t go hard. Especially if you’re not going to be doing your own repairs.
    4runners or jeeps off the showroom floor are not indestructible. In many ways, many mods like oversized tires make them even more tender.
    While part of off-roading fun is in the risk that you might break something, or get stuck, etc, ultimately you can easily choose a “wheeling” style that fits your budget. I personally think that it’s possible to be more gentle on a vehicle during off road travel, than normal busted up urban roads. It’s all in how you decide to drive.
    Curlystooge, 5thToy and Thatbassguy like this.
