What oil to use in differential and transfer case
Discussion in '5th Gen 4Runners (2010-2024)' started by brennaman, Nov 25, 2021.
  1. Nov 25, 2021 at 12:29 PM
    brennaman
    brennaman [OP] New Member
    phil
    2014 4runner
    Just bought a 2015 with 98k on the odometer. I thought I would spend the weekend replacing all the fluids, and would like a little advice from some that have done this already.
    The front and rear diff require 75W-85. The toyota dealer does not sell the oil, and at the auto parts store, they have 75W-90, 75W-95 were the 2 I think I saw, but not 75W-85. I would assume that either would be fine, but I would like to get the right thing.
    As for the transfer case, they call for straight 75W oil. The only one I could find of this was on ebay for about $75 a quart.(had a toyota lable on it) Needing 1.6 qts. I would have to buy $150 of this stuff. Is this really what you put in it? Or do you just get a multi-viscosity and call it a day.
    I tend to replace fluids on a much more frequent interval than manufacturer recommends, so whatever I put in it won't stay more than a couple of years.
    This is my first Toyota, so I do not have any experience with the maint. on them. I really want to make sure I put the right stuff in there. Thanks Phil
  2. Nov 25, 2021 at 1:01 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
  3. Nov 25, 2021 at 1:40 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Forget about Bob, listen to Toyota, post #13 (courtesy of @captrussia253), 75W-90 is fine):
    https://www.4runners.com/threads/wo...ead-of-the-70-toyota-fluid.12858/#post-222929
    captrussia253 likes this.
  4. Nov 25, 2021 at 1:43 PM
    MAXIM
    MAXIM New Member
    I've 75w-85 Redline Oil in both diffs and OEM 75w in transfer case but you can use same 75w85 oil in t/c if don't have access to rare OEM can of gold.
  5. Nov 25, 2021 at 1:47 PM
    MAXIM
    MAXIM New Member
  6. Nov 25, 2021 at 2:08 PM
    captrussia253
    captrussia253 New Member
    Ruslan
    2017 Tundra Platinum 2016 4Runner SR5P on 35s
    I used this in the TC but will likely use a cheaper 75w90 per Toyota. I change diff and TC fluid every 2-3 years. Cheap fluid and peace of mind.
    ElectroBoy likes this.
  7. Nov 25, 2021 at 2:12 PM
    brennaman
    phil
    2014 4runner
    Wow, I just read all of those threads. I should have known that asking about oil is right up there with politics at Thanksgiving dinner. I appreciate all your inputs. The one 75W-85 that walmart has is $38 a quart. Jeez, half of what the toyota stuff is, but since I will be taking it back out in a couple of years, i think I will go with the majority and get 75W-90 for both diffs and transfer. thanks all
    2Toys, DBow14, Toy4X4 and 2 others like this.
  8. Nov 25, 2021 at 2:15 PM
    captrussia253
    Ruslan
    Good call. No need to pay for the expensive stuff.
    RUNNER4DAN likes this.
  9. Nov 25, 2021 at 2:26 PM
    2019 TRDP w/Kangs brah!
    I've been using off the shelf equivalent for years without issues.
  10. Nov 25, 2021 at 6:40 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    On diff and TC worry more about changing the fluid and getting what you can afford, rather than what brand you use. Changing your diff and TC fluid on time makes more of a difference than what brand you use (as long as you get the correct weight and GL)
    Slopemaster and captrussia253 like this.
  11. Nov 25, 2021 at 7:13 PM
  12. Nov 25, 2021 at 7:53 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Royal purple synchromax meets Toyota specs. What I use.
  13. Oct 16, 2022 at 9:40 PM
    taco_runner
    taco_runner New Member
    Kev
    4Runner TRD OR Premium
    I just hit 30K, just changed my engine oil. Now looking to change Transfer Case and both Front and Rear Differential fluid.
    I have watched the Car care nut's video and he said 75W-90 GL-5 is ok on the Transfer case.
    Can I also use the same on Front and Rear differentials??? The manual specifies 75W-85 GL-5, but they are hard to find.
    Thanks
    DBow14 likes this.
  14. Oct 17, 2022 at 1:46 AM
  15. Oct 17, 2022 at 4:39 AM
    himileage
    himileage New Member
    2010 4Runner SR5 2wd & 2013 4Runner SR5 4WD
    I used Redline 75w85 and MT-LV.
    taco_runner likes this.
  16. Oct 17, 2022 at 9:43 PM
    taco_runner
    Kev
    Just ordered from Oh Really ! They are running a 20% discount (CHILLY20) for orders $150 and up. My total came up to $136.77.
  17. Oct 18, 2022 at 2:06 AM
    Matt83
    Matt83 New Member
    Northeast
    I use the Toyota stuff.
  18. Oct 19, 2022 at 10:43 AM
    :eek:Really???!!! What kind of price have you been able to find for that liquid gold?
    Also, what kind of can opener are you using?;)
  19. Oct 22, 2022 at 6:40 PM
    Startrek
    Startrek New Member
    I stand with Toyota fluids: oil, trans, diffs. T4R is way to valuable to go cheap on her. it make total sense when DIY cutting dealership or other auto service labor cost
  20. Jan 19, 2024 at 12:54 AM
    Dreamer170
    Dreamer170 New Member
  21. Jun 9, 2024 at 1:41 PM
    DBow14
    DBow14 New Member
    Don
    Bronco Badlands
    lots
    Dude, it is the same on tractor forums, someone starts talking about hydraulic fluid and which one to use, WATCH OUT! I have used Redline 75W85 because it was Hypoid but I have always used Valvoline 75W90 otherwise, seems like a 5 bump won't make a huge difference and I already have a gallon jug in the garage and it's synthetic, so seems like that would be fine.
  22. Jun 9, 2024 at 3:15 PM
    I used "MAG 1" from the dealership.
  23. Aug 30, 2024 at 9:36 AM
    2014 pepe
    2014 pepe New Member
  24. Aug 30, 2024 at 11:01 AM
    golfpilot
    golfpilot New Member
    David
    Switzerland
    2019 TRD Off Road Premium
    This summer I filled all 3 with Motul Motyl Gear SAE 75W90.
    Of course i have offended the toyota gods. I fully expect to have gearbox damage in the near future ;)
  25. Aug 30, 2024 at 12:32 PM
    2016Pro
    Whatever brand in the proper viscosity
  26. Aug 30, 2024 at 12:39 PM
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    Did this yesterday and today.
    Redline 75W85 for differentials
    Redline MTLV for transfer case
  27. Aug 30, 2024 at 12:45 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
  28. Aug 30, 2024 at 1:04 PM
    This is what I use as well.
    Just because I don't want to bust out my pump. The bag make it easy and fast.
  29. Aug 30, 2024 at 1:07 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    this is what I use
  30. Aug 30, 2024 at 2:13 PM
    iamthestig
    iamthestig New Member
    Central Texas
    2020 Midnight Black OR
    Rad Rubber Splash Guards
    +1 For this as well for diffs. Easy to use and meets specifications.
