What is this noise?
Discussion in '4th Gen 4Runners (2003-2009)' started by Toblerone, Aug 22, 2025 at 6:25 PM.
  1. Aug 22, 2025 at 6:25 PM
    Toblerone
    Toblerone [OP] New Member
    Friday
    2008 Gen 4 urban runner
    GEN 4 4RUNNER Urban Runner
    Recently rebuilt engine
    Coils and plugs are good
    All cylinder pressures are good (so valves and lifters should be good)
    No Codes except random misfires every few hundred miles but only on starts. Starts are pretty rough unless I give it a little punch on the gas pedal.
    Sounds like timing chain rattle or VVT timing chain but again, no codes.
    Also this noise doesn't come out until the engine is warm.
    Youtube video here
  2. Aug 22, 2025 at 6:27 PM
  3. Aug 22, 2025 at 6:31 PM
  4. Aug 22, 2025 at 6:46 PM
    Sounds a lot like the timing chain tensioner is not bolted down, and the timing chain and tensioner are both flapping around in there.
    Does the sound go away when you rev it up? This puts tension against the chain and pulls it tight while the chain is under load.
  5. Aug 22, 2025 at 7:47 PM
    Toblerone
    Friday
    No the sound gets faster as the engine revs
  6. Aug 22, 2025 at 7:56 PM
    Startrek
    Startrek New Member
    what I learn from TCCN that sound will continue without any harm unless you change VVTi gear unit for new, not affected by high mileage. something inside VVTi unit give way, not harm and VVTi work OK - no codes. call it "slapping sound" and live with it. do not tear engine apart until you have codes
  7. Aug 22, 2025 at 8:23 PM
    Toblerone
    Friday
    Thank you. My mechanic was very reticent to open in up. I may open the tensioner window to check the timing chain but this engine was just rebuilt. May go back to the guy who sold me the rebuilt engine but he's a total scrub.
    White TuRD likes this.
  8. Aug 22, 2025 at 8:46 PM
    White TuRD
    White TuRD New Member
    SC
    2021 TRD ORP
    That is not acceptable for a “rebuilt” engine (which should have come with a warranty)
  9. Aug 24, 2025 at 6:30 AM
    Welcome from Wisconsin!
