What is a good "performance" air filter you guys are using with these rigs?
Discussion in '5th Gen 4Runners (2010-2024)' started by Trail Addict, Sep 17, 2023.
  1. Sep 17, 2023 at 7:43 PM
    Trail Addict
    Trail Addict [OP] Professional Driver on a Closed Course
    2022 4Runner TRD Pro
    I read somewhere the TRD one is being discontinued. So what are you guys using? Please paste part numbers if you have them.
  2. Sep 17, 2023 at 7:50 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro
    alittleoff likes this.
  3. Sep 17, 2023 at 8:59 PM
    2020 Venture / 2017 Tacoma
    K&N is what I use on all the filters. A bit pricier but they seem to last more.
    BillyE likes this.
  4. Sep 17, 2023 at 9:08 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Pretty happy with K&N
    BillyE likes this.
  5. Sep 17, 2023 at 9:18 PM
    fyi many dudes will say no - you should use Wix, or genuine Toyota paper filters, as there is worries with K&N questioning how well it filters dust. But K&N 33-2438 has done me just fine, washable and sh*t so I haven't had to replace often.
  6. Sep 18, 2023 at 12:17 AM
    This^
    Plus if you over oil a K&N, it will cause residue on the mass airflow sensor.
    Stick with OEM, especially it you off road in dusty environments.
  7. Sep 18, 2023 at 12:21 AM
    2019 TRDP w/Kangs brah!
    OEM because a filter does nothing. I even run OEM in the TRD airbox.
  8. Sep 18, 2023 at 8:29 AM
    I use Wix, not opposed to K&N but I did have the issue with the mass air flow sensor. Ended up just having to clean it and that worked. I think the issue is over oiling after re-wash. I am guilty of that.
    Mass4runner likes this.
  9. Sep 18, 2023 at 9:59 AM
    Depends on what you mean by performance? High filtration performance for doing dusty trails and just generally keeping dust out of the engine? Or high airflow performance for a slight boost in acceleration/power?
    If filtration is the goal, then OE.
    If you want to boost acceleration by a horsepower or two, the air filter isn’t the place to do it, especially for a 4runner that might end up sucking dust at some point. Not worth the risk.
    If you’re ever bored, hold up a K&N filter to the sun, and count how many pinholes you can see that let light directly through. They really don’t filter that all that much. It’s fine for a race engine that get’s rebuilt frequently, but it might cause longevity issues for a daily driver, for very little benefit.
  10. Sep 18, 2023 at 4:14 PM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    I concur!
  11. Sep 18, 2023 at 4:27 PM
    Badger007
    Badger007 New Member
    David
    Kilmarnock, Virginia
    2023 Gray 4Runner Limited
    I installed an S&B cold air intake. About $300. It allows 43% additional air intake, which has improved performance in terms of engine response.
  12. Sep 18, 2023 at 4:31 PM
    beedee
    beedee Member
    My buddy gave me a brand new K&N for my 2011 Pro-4x Xterra (he didnt want to put it in his X), it fouled my MAF within two days.
    2016Pro likes this.
  13. Sep 18, 2023 at 4:42 PM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Remember, even if the CAI does improve airflow into the engine by 43%, if you don't increase the exhaust airflow by the same amount, you've gained pretty much nothing.
  14. Sep 18, 2023 at 5:06 PM
    johnparjr
    johnparjr New Member
    New Caney, TX
    2023 4Runner Off Road Premium
    OEM or Wix
    kolter45 and 2016Pro like this.
  15. Sep 18, 2023 at 6:19 PM
    Shitty
    Can't go all in believing everything you hear; literally never had any issues multiple winters and summers. No maf residue malfunctions. But hell I barely even have to clean it - my wife drives the truck majority of the year 5 min to work in our town. And let just say I don't have or need a snorkel. K&N works well for me
  16. Sep 18, 2023 at 6:35 PM
    That being said, I din always run k&N but wanted to try, and I don't plan to forever because of the obvious long term oil build up risk. And although it's durable I hear it only stops approx 85% of debris as it's letting a lil more air in.
    OP did ask, what "performance" filter do you recommend. I'm interested to know what would ya'll say is Wix or OEM paper better "performance"
  17. Sep 18, 2023 at 7:38 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I've been using an AEM washable filter for over 100k miles. Currently it has 108+k on the ticker.
    I wash it every other oil change.
    Back when we bought our '16 in 12-2015, the price of the AEM was 3 times the price of a factory filter but, I was in it for the long haul and didn't look back.
    I also run an AEM in my '03 TJ. Currently it has 88+k miles. Admittedly the TJ see more dirt roads but, the intake tube and TB stay
    clean.
  18. Sep 18, 2023 at 8:49 PM
    2016Pro
    Save your money, no such thing as a performance air filter
    HighSierraGuy likes this.
  19. Sep 18, 2023 at 8:51 PM
    2016Pro
    K&N = snake oil
    Cis915 and HighSierraGuy like this.
  20. Sep 18, 2023 at 9:09 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    If you really want some filtration, then run a snorkel like they do down in Straya.
  21. Sep 18, 2023 at 9:26 PM
    I’m pretty sure I’ve even seen inertial particle separators mounted on top of snorkels for even more filtration.
    bassist[QUOTED] likes this.
  22. Sep 18, 2023 at 9:55 PM
    HighSierraGuy
    HighSierraGuy New Member
    OEM, performance air filters are a gimmick
    Cis915, Too Stroked and 2016Pro like this.
  23. Sep 19, 2023 at 10:33 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    But seriously, use a dry paper filter.
    JET4, 5thToy, 2016Pro and 1 other person like this.
  24. Sep 19, 2023 at 12:43 PM
    Eubeenhadd
    Eubeenhadd Bit of a derp
    Indianapolis
    2005 T4R 4.7 AWD
    Spartan Locker, OME 885/895w/stiff Nitrochargers, 265/70R17 Encounter AT
    I used one a while back that added a lot of power, it was really neat. It spun to drive the engine harder, seemed like it was driven by the exhaust.
    Anything else is a waste, the engine will not gain enough noticeable power to offset the costs of letting your engine suck more dust.
  25. Sep 19, 2023 at 1:51 PM
    steelevo
    Utah
    The best performance will always come from a clean OEM/ non-restrictive filter.
    djwantke likes this.
  26. Sep 19, 2023 at 2:09 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Dry filters are the best. I'm running an injen intake which i like. Easy install, easy to clean, and I got it cheap. I had a s&b intake in my tacoma( which i also liked). Pretty much you won't feel much if any increase in performance. Sounds good though.
    2016Pro likes this.
  27. Sep 19, 2023 at 2:40 PM
    HighSierraGuy
    That's called a turbo charger, minus the exhaust part.
    McSpazatron and 08TXRunner like this.
  28. Sep 19, 2023 at 3:27 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Another cluster fuck air filter thread.
  29. Sep 19, 2023 at 5:43 PM
    But if you are serious, I doubt you mean an actual turbo. Since most people would remember for sure if they installed a turbo.
    But maybe it’s this you’re talking about? AE497ACC-7972-4434-A7D7-37A1BF3BE0B9.png
    But these aren’t driven by exhaust. They just go inside the the intake tube and literally impede airflow due to the space it takes up in the intake tube, and the energy it takes to windmill the toy fan. The bearings are cheap toy things as well and usually fall apart and get ingested directly into the engine. Physics dictates these will reduce power, not increase it. Also, they don’t filter air because you install these after the air filter.
  30. Sep 20, 2023 at 6:33 AM
    Eubeenhadd
    Indianapolis
    2005 T4R 4.7 AWD
    Yeah I was talking about a turbo.
    I did mean an actual turbo. I'm aware they don't filter. I was shitposting and I'm sad y'all couldn't tell I was joking, I'll try harder next time.
