What is 4-D vs regular D? And when should I use it?
Discussion in '4th Gen 4Runners (2003-2009)' started by Cingle08, Dec 10, 2018.
  1. Dec 10, 2018 at 7:36 AM
    Cingle08
    Cingle08 [OP] New Member
    Charlie
    2007 Silver 4Runner
    Just got a 4Runner and I’m not familiar with these options, thanks for your help!
  2. Dec 19, 2018 at 2:21 PM
    That_Titanium_4RNR
    That_Titanium_4RNR New Member
    Michael
    Greenville NC
    2006 Titanium Limited V8 4X4
    Dobinsons awning, TPMS Bypass, AIP Bypass, HCF Delete, LED License Plate Lights, LED Reverse Lights
    I believe putting it in 4 allows transmission to go to 4th gear but no higher. I can do 1,2,3,and 4 in this mode but not 5. D allows it to use all gears however it sees fit. As far as when you would want to use 4 I don't know...I know some people when offroading put their vehicles into 1st or 2nd gear but I typically have no issues keeping it in D and 4HI, if I really am having issues I will do 4LO
  3. Dec 19, 2018 at 2:28 PM
  4. Dec 19, 2018 at 6:26 PM
    Sparkkky
    Sparkkky New Member
    2018 4 Runner TRD Off-road
    Eiback Pro lift, ARB Summit bumper, Smitty Bilt wench, Summit flood LED
    4 D is for towing, not good to tow in overdrive.
  5. Dec 19, 2018 at 6:51 PM
    4runningMan
    4runningMan New Member
    New Mexico
    When in just plain "D", you'll have access to gears 1-4 plus 5, which is overdrive. This allows you to get better mpg at speed. You'll use it for daily driving.
    But as mentioned, when towing, the overdrive is too high of a gear. So, you essentially cut off the ability of the truck to shift into overdrive.
