What else do you drive or ride?
Discussion in 'General Automotive' started by LMR, Apr 24, 2014.
  1. Sep 21, 2025 at 12:14 PM
    #1171
    Shredder and gkomo like this.
  2. Oct 3, 2025 at 2:57 PM
    #1172
    Im gonna film Fast and Furious 12 from my driveway.
    Steely123 likes this.
  3. Oct 3, 2025 at 3:43 PM
    #1173
    Rocket-67
    Rocket-67 New Member
    Chris
    SE New Mexico
    '19 4 Runner TRD Off-road
    My go to rides
    2013 FXD Wideglide
    2022 Pan America Special
    Thacrow likes this.
  4. Oct 4, 2025 at 2:16 PM
    #1174
    I got invited to "IROC" church?
  5. Oct 10, 2025 at 1:34 PM
    #1175
  6. Oct 10, 2025 at 1:36 PM
    #1176
    Just saw a brand new truck cruise by with a bent hood and front end. Deer prob.
  7. Oct 10, 2025 at 2:07 PM
    #1177
    Rocket-67 likes this.
  8. Nov 7, 2025 at 4:51 PM
    #1178
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    2025 Durango R/T Hemi
    courtesy car while work truck in shop
    :burnrubber:
    engineer90 likes this.
  9. Nov 8, 2025 at 7:12 AM
    #1179
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
  10. Dec 11, 2025 at 7:18 PM
    #1180
  11. Dec 11, 2025 at 9:39 PM
    #1181
    NeverTooLate71
    NeverTooLate71 New Member
    Bob
    2024 4Runner SR5
    Idaho, Oregon?
  12. Dec 15, 2025 at 7:27 AM
    #1182
    Blackshirt
    Blackshirt New Member
    ‘24 SR5 Premium 4WD
    My E-Truck:
    (EZ-Go TX48)
    Shredder likes this.
  13. Dec 15, 2025 at 9:51 PM
    #1183
    NeverTooLate71
    Bob
    2024 4Runner SR5
  14. Dec 16, 2025 at 3:43 AM
    #1184
    Rocket-67
    Chris
    SE New Mexico
  15. Dec 16, 2025 at 5:06 AM
    #1185
    engineer90
    engineer90 New Member
    NJ
    2023 TRD Off-Road Premium
    The 3.6R is a sleeper
    Pentangler and hossler1788 like this.
  16. Dec 22, 2025 at 12:40 PM
    #1186
  17. Dec 22, 2025 at 3:36 PM
    #1187
  18. Dec 22, 2025 at 4:37 PM
    #1188
    Shredder
    Shredder New Member
    tip of the mitt, Michigan
    23 OR
    Tires, shocks
    Hah! I laugh at winter. A 2006 new holland TC33 keeps my drive clear
    Technologic80 likes this.
  19. Dec 22, 2025 at 4:53 PM
    #1189
    Danno83
    Danno83 New Member
    Southern Louisiana
    2024 Silver TRD ORP
    TRD Pro grille, blackout badging, Toyota Orweillian tracking delete.
  20. Dec 22, 2025 at 5:03 PM
    #1190
    BoiseG
    BoiseG New Member
    2024 ORP
    2013 Yamaha Grizzly 550 EPS
  21. Dec 22, 2025 at 5:35 PM
    #1191
    Lunar-TRD-Pro
    Lunar-TRD-Pro New Member
  22. Dec 24, 2025 at 3:53 PM
    #1192
    Its going to be a "Kyonari" christmas!IMG_2111.jpg You cant get a large. I lucked out with one with stickers, hopefully they come off and dont leave a permanent mark.
  23. Dec 24, 2025 at 4:38 PM
    #1193
    Here's the helmet. 151's are those air-bag suits ai think. And it has a track on the back of the added airfoil.IMG_2113.jpgRed face shield
  24. Dec 24, 2025 at 4:51 PM
    #1194
    The 01' Suzuki GSXR 750, that Matt Mladon won the Daytona 200 on, Is going antique next week! Its got 20k miles. Just getting broke in.
  25. Dec 24, 2025 at 7:25 PM
    #1195
  26. Dec 24, 2025 at 8:22 PM
    #1196
    Technologic80
    Technologic80 Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    I have 7 other vehicles, probably all too mundane to list for afficinados like yourselves, lol but just picked this up yesterday - 2019 F-150 3.5L 37k miles, nicely optioned for an XLT. $25k! Clean carfax and regular maintenance, looks like the owner changed the oil every 3k, 4k tops. Drove it 200 miles today home and it drove great! Now I have something to haul/tow with (we have a 30' travel trailer that the 4Runner would self immolate itself if I ever hooked it up lol). We also have another F-150 ('23 Powerboost) and have leased them for the past 11 years. Not getting rid of my 4R but this will accompany it in the garage for sure :cool:2.2.jpg
  27. Dec 26, 2025 at 6:57 PM
    #1197
    Road America Elkhart Lake Wisconsin. 4.048 miles of pure pornography! Best in the nation. The carousel pic, turn 9 with this helmet!
    Rocket-67 and Toy4X4 like this.
  28. Dec 26, 2025 at 7:48 PM
    #1198
    If I knew he rode Yamaha I would not have bought it?
  29. Dec 27, 2025 at 3:27 AM
    #1199
    The Carousel looks fun! Canada corner (12) is awesome also.
  30. Dec 27, 2025 at 5:06 AM
    #1200
    Always have to have the reliable untouched work horse.
    Technologic80[QUOTED] likes this.
