What do people have for tires these days. Need new tires! 285s.
Discussion in '5th Gen 4Runners (2010-2024)' started by Fried_man007, Oct 16, 2025.
  1. Nov 3, 2025 at 4:52 PM
    #91
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Miles, and the USA, are who is wacky.
    (I’m dual citizen tho USA/CAN)
  2. Nov 3, 2025 at 6:27 PM
    #92
    Maybe Airdams truck is stuck in KM mode?
  3. Nov 3, 2025 at 6:32 PM
    #93
    live in mississippi
    aint ever seen them kilometers on the dash
    Saker likes this.
  4. Nov 4, 2025 at 6:27 PM
    #94
    Which comparison website is dis
    Thanks
  5. Nov 4, 2025 at 8:17 PM
    #95
    I use Discount tire to compare.
    1) After you select the size and do any kind of filters you want click on the compare check box on the tires you are interested to compare.
    2) When you select upto 4 tires you want to compare hit on compare button on right
    3) Scroll down to tire specs
    djwantke[QUOTED] likes this.
  6. Nov 17, 2025 at 1:49 PM
    #96
    osiris3006
    osiris3006 New Member
    2024 Toyota 4runner TRD Pro
    stock
    Do you think the results would be similar with the general apt?
  7. Nov 17, 2025 at 2:07 PM
    #97
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Stock & No issues W/current ones, nor ANY Toyota I have bought! 2 FJ's, 1 Tacoma & 2 4Runners.Keep aired to correct PSIG, Rotate & you'll be fine!
  8. Nov 17, 2025 at 3:03 PM
    #98
    If they are Load Range E yes I would bet they would have the same mileage. I believe the LRE tires have a harder rubber compound to allow the tire to last longer on a heavy truck. These tires claim to have 60,000 warranty on all loads. Well how would that work if they all have the same rubber. How would you possibly get the same mileage out of a set on a regular cab pre-runner Tacoma as you would a mega cab 2500 hauling heavy?
    I think the rubber is different compounds for the different load ratings. I got right around 70,000 out of my LRE General grabbers on my mega cab that towed nearly every day of its life. I think that’s how I got such high mileage out of these LRE on my 4R. The ram 2500 with tongue weight is around 2700-2800 pounds per corner. The 4Runner is about 1100 pounds per corner. I think the reduced weight, increased tread life. My plans are to get LRE tires from now on if they’re available. If not get the highest weight rating you can get such as a Load Range D. I suspect the SL and C ratings will likely also give you the advertised 60,000-70,000 but I am showing you with my own that a LRE will go well over 100,000 without breaking a sweat.
  9. Nov 30, 2025 at 12:47 PM
    #99
    osiris3006
    stock
    Have you installed the outpost? How do you like them?
  10. Nov 30, 2025 at 11:33 PM
    #100
    Its too early to give a good feedback. As initial feedback I can say;
    It's slightly firm than Toyo Open County but not too bad for a Standard load tire. I run 32psi now vs 34-35psi before.
    Road noise is teeny bit louder but not even close to Goodyear Wrangler Duratrac level.
    Driving feel (acceleration and Cornering) I don't feel any difference. Probably since my old Toyo and this is same weight if I'm not mistaken.
    No proper snow & ice, wet roads or offroad driving yet.
