What did I do? Differential damage? 4 WH test and now yuck sound...
Discussion in '5th Gen 4Runners (2010-2024)' started by racepointrunner, Apr 12, 2025.
  1. Apr 12, 2025 at 11:33 AM
    racepointrunner
    racepointrunner [OP] New Member
    Ted
    Cape Cod
    '13 SR5, 08 SR5 for beach/offroad, 07 Sport Edition RIP at 202K
    none, other than AT tires for offroad
    Ugh, this may be my ignorance and stupidity, but I tested my 4wd High today on wet road, then tried parallel parking, leading to slippage and a clunk. I switched back to 2H, but now i have a low vibration and soft whirr sound when driving, more prominent when I get between 30-45mph. Ooof, that gut punch feeling of "what did I do" sucks. I just bought this 2013 4TR with 88K 2 weeks ago from Toyota dealer, its still covered under 30 day warranty, but I fear I may have done this damage to myself. Ive had 2 Gen 4s where this only happened on sharp turns on pavement getting off sand/offroad, so since have disengaged prior to getting off trail. Already have an appt to bring it in next week for what I thought was very slow power steering loss. Anyway hoping you all can give me advice on next steps.
  2. Apr 12, 2025 at 11:37 AM
    From what I read
    You can only go straight in 4h
    Dan's 4runner likes this.
  3. Apr 12, 2025 at 11:39 AM
    You can make turns in 4H, but a gradual turn. You can't make a 90 degree right hand turn when you're in 4H. Ask me how I know! :)
  4. Apr 12, 2025 at 11:39 AM
    leftyfire
    leftyfire New Member
    Michael
    Colorado Springs
    2006 Limited V6
  5. Apr 12, 2025 at 11:50 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    racepointrunner[OP] likes this.
  6. Apr 12, 2025 at 11:52 AM
    2020 Venture / 2017 Tacoma
    Get underneath and see if there are any signs of leaks or seeps from the front and back diffs. Sometimes there could be a weird smell that comes from the diffs like burnt oil or something like that. I think the issue was too much torque and turning at the same time. The diffs could be fine for all you know but maybe a cv axle or rod was already weak and you stressed it even more. Don't jump the gun too quickly with what the dealer will tell you unless you trust them and they are good. If the diffs were damaged and you ever want to go up in tire size this might be a good chance to regear and do all of that jazz...of course if you are into all that offroad stuff. If stock is your thing....proceed business as usual and get it fixed. Lesson learned - we break things all the time. Good luck.
    P.S. post pics - you might get more advice from others here with visuals.
    icebear and racepointrunner[OP] like this.
  7. Apr 12, 2025 at 11:54 AM
    Owwie I'm sorry for you.
    I too had a mishap after going from dirt to asphalt... what is that noise???
  8. Apr 12, 2025 at 11:54 AM
    racepointrunner
    Ted
    Cape Cod
    Do i cop to messing this up myself? Or try to plead ignorance? Seems like a pretty obvious cause and effect, and it certainly didn;t do this before i bought it...
  9. Apr 12, 2025 at 11:59 AM
    TeslasBigCarbonFootprint
    2014 Neglected by the previous owners 2020 is an abused former rental... 2023 New
    I would try to get on to a gravel or dirt road and gently exercise 4H & 4L for a while, how about a mile at slow speed.
    Maybe things will "settle" back into place.
    During my monthly exercise, when the wheel gave me a little bit of resistance, I didn't force it and immediately researched it. That's where, on this forum, somebody mentioned to use it online gravel or dirt.
  10. Apr 12, 2025 at 12:02 PM
    racepointrunner
    Ted
    Cape Cod
    I'm not seeing leaks or smelling anything, nothing to take pics of that I can make out, but its rain/snow snotting out, so didn't full out get under there. I guess I'll find out when I take it in. I'm planning on keeping stock for now, as I'm not doing any heavy offroading.
  11. Apr 12, 2025 at 12:15 PM
    racepointrunner
    Ted
    Cape Cod
    Yeah, that was my hope, so I tried engaging between 2wd and 4hi a couple times going straight at about 10-20mph, but that did not seem to settle anything... F !!!
  12. Apr 12, 2025 at 12:16 PM
    Daddykool
    As said before, take it out on some very loose surface and slowly run it through 4H/4L, slow, small turns, and see if it gets back to itself. Can't hurt.
  13. Apr 12, 2025 at 12:17 PM
    No biggie. It turned out well. I didn't try to force it. After hearing a weird "thunk" noise I backed off, straightened the wheels. Then let it sit for few minutes. All was well again.
    That reminds me; it's time to put it in 4H & 4L to exercise those gears. I need to find the nearest mall. You know, so I can flex for Instagram.
    Photon_Chaser, Saker, icebear and 2 others like this.
  14. Apr 12, 2025 at 12:17 PM
    Daddykool
    I recommend honesty.
  15. Apr 12, 2025 at 12:21 PM
    Just trade it in for another 3runner!!
  16. Apr 12, 2025 at 12:22 PM
    Cop to it and be honest.
    You should also try to bribe the guy in charge at the dealership with sexual favors. Sure, he may reject you, but the look on his face and the awkwardness will be an awesome story to tell your friends. Make the offer WHILE you are shaking his hands and pull him close to you when you say it.
  17. Apr 12, 2025 at 12:23 PM
    Daddykool
    Is that experience speaking?
  18. Apr 12, 2025 at 12:24 PM
    I may or may have not whored myself out for Toyota accessories and free body work. Do not shame me!
    TrailSpecial22, brownersd and Saker like this.
  19. Apr 12, 2025 at 12:26 PM
    Daddykool
    Your secret is safe here...
  20. Apr 12, 2025 at 12:29 PM
    How many trips before they hand me a snorkel intake you think?
  21. Apr 12, 2025 at 12:44 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Neither. Bring it in and tell them there seems to be a problem. They can investigate on their own and figure out what's wrong. Unless is it one you trust, most dealerships will try to put the blame on the owner (even when not justified) so no need to give them a reason to do so.
    Besides, who knows what the issue really is. It is possible it has nothing to do with what you did. Correlation is not always causation.
    Number16, brownersd, Saker and 2 others like this.
  22. Apr 12, 2025 at 1:38 PM
    CarlP
    CarlP New Member
    Carl
    Phoenix, AZ
    2018 Off Road with KDSS
    Do yourself a huge favor; when you exercise your 4WD, do it on DIRT ONLY!
  23. Apr 12, 2025 at 1:47 PM
    2019 TRDP w/Kangs brah!
    4wd is not AWD unless it’s full time which only the limited has. These aren’t Subarus.
    You can exercise it on straight paved roads without issues. Also it’s a Toyota so it’s lt going to easily break.
  24. Apr 12, 2025 at 2:22 PM
    Take it back. You did nothing wrong
  25. Apr 12, 2025 at 3:01 PM
    Does the vibration go away in 4hi? It's possible you simply have the front diff needle bearing vibration and are just noticing it now.
  26. Apr 12, 2025 at 3:03 PM
    leftyfire
    Michael
    Colorado Springs
    2006 Limited V6
    I think this is on his '13. Not the 4Gen
  27. Apr 12, 2025 at 3:19 PM
    racepointrunner
    Ted
    Cape Cod
    Ha, yeah, I'll be sure to look for that 5 finger discount
  28. Apr 12, 2025 at 3:22 PM
    Indeed. Still waiting for my morning coffee to kick in.
    leftyfire[QUOTED] likes this.
  29. Apr 12, 2025 at 3:24 PM
    racepointrunner
    Ted
    Cape Cod
    Did this a couple times on gravel, which did help quiet it down. I'm still gonna take it in, seems some slight noise still. Anyway, thanks for the help!
    Daddykool[QUOTED] likes this.
  30. Apr 12, 2025 at 3:49 PM
    racepointrunner
    Ted
    Cape Cod
    Thanks, this helped, though I'm still gonna bring it in have em check it out. much quieter, but still something there. Heh, some of these clowns on here are almost as good as my beer league hockey goons
