What’s cool under your rig’s hood besides awesome 4.0L 1GR-FE?
Discussion in '5th Gen 4Runners (2010-2024)' started by MAXIM, Feb 28, 2026.
  1. Feb 28, 2026 at 5:58 AM
    MAXIM
    MAXIM [OP] New Member
    Supercharger, air compressor, turbo or air pump delete?
    -and-lt;-and-lt;-and-lt;-and-lt;-albums-_7d76dd38d92d765d0e72378a8387c829a920fdfb.jpg
    ToyotaDude99 and djwantke like this.
  2. Feb 28, 2026 at 10:30 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    My Northstar x2 battery that's going on 4 1/2 years.
    BS67 likes this.
  3. Feb 28, 2026 at 10:47 AM
    mcat707
    mcat707 MURDERED TURD PRO
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
    Not sure about cool looking but it’s there when I need it.
    aleggsue, Hagglethorn, BS67 and 2 others like this.
  4. Feb 28, 2026 at 11:23 AM
    Filter minder on the air cleaner housing.
    Gman2530, BS67, MAXIM[OP] and 2 others like this.
  5. Feb 28, 2026 at 11:59 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    just auxiliary lighting
    Gman2530, Saker, BS67 and 4 others like this.
  6. Feb 28, 2026 at 12:06 PM
    Very tidy!
  7. Feb 28, 2026 at 12:10 PM
    ToyotaDude99
    ToyotaDude99 Obsessed with 4Runners... And anything Toyota
    Indeed it is. Looks nice and neat. Better than mine!
  8. Feb 28, 2026 at 1:56 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    I would like to have that on mine, but I don't want to spend for the TRD so-called cold air intake. Is it available separately? Did you install yourself?
    ToyotaDude99 likes this.
  9. Feb 28, 2026 at 2:55 PM
    Yes I installed it myself.
    The Toyota branded ones are getting scarce I think but you might find one if you do a little hunting. If you can’t find one, not to worry. @GrizzlyPro in this thread got the same item without the Toyota branding from NAPA. Part number FIL4801.
    You may need this grommet.
  10. Feb 28, 2026 at 3:34 PM
    mac1usa
    mac1usa New Member
    A block of wood and towel to avoid scratches. These are used to prop the hood up slightly to keep my battery tender hooked up over winter. It’s almost time for her to come out to play.
    TJH-6, Gman2530, 2Toys and 2 others like this.
  11. Mar 1, 2026 at 7:41 AM
    thanks you guys
    appreciated.
    pretty sure I blately stole the idea from @2Toys @Saker
    *I just velcro’d to the fuse box lid, they might have bolt on trays
  12. Mar 1, 2026 at 7:59 AM
    Where did you source the grommet from? The Amazon link in post #9 did not return any specific product...
    ToyotaDude99 and 2Toys like this.
  13. Mar 1, 2026 at 8:50 AM
    2Toys
    Gordon
    2019 4Runner TRDORP
    Good morning, Gary. I am pulling the trigger on this mod and starting to gather the pieces. I too found the Amazon links useless. I have reached out to Donaldson for a quote, and I plan to visit a local Napa store on Monday (closed today). I will let you know findings.
  14. Mar 1, 2026 at 10:39 AM
  15. Mar 1, 2026 at 10:46 AM
    2Toys
    Gordon
    2019 4Runner TRDORP
  16. Mar 1, 2026 at 2:04 PM
  17. Mar 1, 2026 at 2:08 PM
    DocSR5
    DocSR5 New Member
    Cave Creek, AZ
    2023 SR5
    That wooden block could use some paint correction and a fresh ceramic coat Lol!
    Gman2530 and ToyotaDude99 like this.
  18. Mar 1, 2026 at 2:43 PM
    mac1usa
    mac1usa New Member
    Ha would you believe that wooden block has been around for probably 30 plus years. I remember my Grandfather notching it out to use jack up his boat trailer for the winter (now my boat through inheritance). It is the only thing tall enough I had to prop up the hood just enough. I did not want to leave the hood up all winter and this way it’s up a few inches and I can still get the cover down to the bumper.
  19. Mar 1, 2026 at 3:23 PM
    DocSR5
    DocSR5 New Member
    Cave Creek, AZ
    2023 SR5
    Love it!! Id have done the same thing in not keeping the hood up all winter. And yes, keep that block forever. It’s got sentimental value.
    2Toys, ToyotaDude99 and alittleoff like this.
  20. Mar 1, 2026 at 3:34 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    It's funny to think about all of the tools that follow us around for so many years.
    Just today, installing new wheels & tires on my neighbors Trans Am, I used a torque wrench that I remember using back in the 1960's while helping my Dad work on our vehicles. In High School I made a set of car ramps out of 1" angle iron that are still in use today. And I'm pushing 67yo.
  21. Mar 1, 2026 at 4:54 PM
    Gman2530
    Gman2530 New Member
    2018 SR5 4wd 4Runner
    We may be the last generation that truly appreciates a nice block of wood :hattip:
    Hollowdawg, 2Toys, NB4x4 and 2 others like this.
  22. Mar 1, 2026 at 5:32 PM
    mac1usa
    mac1usa New Member
    That’s ironic I have a set of wooden hand made ramps my Grandpa used to change oil on his Econoline van. I don’t trust them for a vehicle despite being inside. I used them for odd things like lawn mower etc. I remember years ago losing a coworker when a car fell on him changing his girlfriend’s oil. I am always extra safe with that stuff now. But I still have Grandpas old ramps, tools, and fishing equipment
    That old fishing stuff still works well too. The fish have no idea how old it is :)
  23. Mar 1, 2026 at 6:04 PM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Hey I'm 16 and hoard wood! Also trying to figure out how to fund a bandsaw mill. I'm not normal...
    YELDARB, alittleoff and ToyotaDude99 like this.
  24. Mar 1, 2026 at 6:43 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    does this count?
  25. Mar 1, 2026 at 7:14 PM
    ToyotaDude99
    I'm also the same. Wood has so many uses. I'm 16 too
    NB4x4[QUOTED] and 2Toys like this.
  26. Mar 1, 2026 at 7:20 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    I have a 1/2 drive standard socket set from K-Mart that my mother's father (self taught engineer that designed cars and trucks for General Motors) gave me when I was probably twelve years old so that I could do my own work on my bicycle. I will be 65 this year, and I have only broken one socket out of that cheap tool set and still use it occasionally as a professional.
  27. Mar 2, 2026 at 5:20 AM
    alittleoff
    Steve
    406
    '16 TP
    Attention Shoppers, we have a blue light special.
    We had one local to us back in the day in SoCal. It was the predecessor of many of the big box stores of today.
    In another town near our place now, one of the last remaining stores was recently closed forever.
    Gman2530 and NB4x4 like this.
  28. Mar 2, 2026 at 7:44 AM
    Both of you sound like the right kind of “not-normal” to me! Scrap wood (or plastic or metal) is often more useful than getting fresh material at the store.
    It’s just that, sometimes, a piece of scrap has to wait 20 years before it finds its purpose lol. But when that day comes, it will be glorious :p:D
  29. Mar 2, 2026 at 9:15 AM
    Amen. I've had several neighbors who've replaced fencing, and I've turned their old fence boards into any number of furniture pieces around my and other's houses around me.
  30. Mar 4, 2026 at 12:36 PM
    What's happening here? You took the plastic mice-shelter from a Tundra and stuck it on your 4.0L?
