Weird unlock behavior using fob.
Discussion in '3rd Gen 4Runners (1996-2002)' started by Shadco, Dec 21, 2021.
  1. Dec 21, 2021 at 6:43 PM
    Shadco
    Shadco [OP] New Member
    2K 4Runner LTD
    If I lock the car with the fob and unlock shortly after everything works as it should, first press unlocks drivers door, second all doors.
    if I leave the car for a few minutes and unlock with the fob the alarm goes off and I have to use the key to stop it.
    I have 2 fobs programmed and both behave the same way.
    Anyone have any ideas?
  2. Dec 21, 2021 at 7:15 PM
    How old is the battery in the runner? Sometimes it goes a little goofy when the battery is going out.
  3. Dec 21, 2021 at 7:31 PM
    Shadco
    2K 4Runner LTD
    Funny you would say that.
    I’m prepping this one for my daughter out in SW Colorado, she’s a field guide and spends a lot of time in the boonies.
    The old battery tested weak today so I swapped it out with a group 34, it had an old group 25.
    I didn’t test if after the swap I will tomorrow.
  4. Dec 21, 2021 at 7:34 PM
    Hold on? The key turns off the alarm? Well, there goes my “hide a key under the front-end and it won’t start without the fob idea.”
    Just removed my spare key. I have my alarm set to arm, with doors unlocked, but sometimes it will lock, on its own.
    There are a few settings you can change on the brain, I have the manual.
    Like auto arm, auto lock, turn the chirp off. And add new fobs. pretty sure it’s the same for yours.
  5. Dec 21, 2021 at 7:39 PM
    Shadco
    2K 4Runner LTD
    Are those instructions in the owners manual? I programmed a couple of fobs today, it wasn’t easy since the drivers door lock cylinder was worn out and the actuators were tired so I swapped the lock cylinder with the passengers side. My hands are now a mess.
  6. Dec 21, 2021 at 7:41 PM
    Yep, 4 years older prob the same.
  7. Dec 22, 2021 at 8:04 AM
    Shadco
    2K 4Runner LTD
    Annoying it still does the same thing I need to unlock the doors with the key if I use the fob when more than a few minutes have passed the alarm goes off and I have to use the key to turn the alarm off and open the doors.
  8. Dec 30, 2021 at 9:31 AM
    Shadco
    2K 4Runner LTD
    So after reading the alarm portion of the manual I think the issues is that the alarm arms after 30 seconds and for some reason when I use the fob it thinks I’m forcing the lock on the door.
