Weird tire noise
Discussion in '3rd Gen 4Runners (1996-2002)' started by wncsellers, Jan 19, 2025.
  1. Jan 19, 2025 at 10:45 AM
    wncsellers
    wncsellers [OP] New Member
    Wesley
    Boone North Carolina
    2001 SR5 2WD Auto stock
    My 2Runner is making a semi loud noise that I believe is from the drivers front side. It doesn’t cause any noticeable vibration, and the car still goes straight when I take my hands off the wheel. I will try and link the video below.
    https://youtube.com/shorts/68vpG4ZR8VI?si=HnHGMi_gZ8W1vTuc
  2. Jan 19, 2025 at 6:08 PM
    Put your spare tire on and see if the noise goes away? Or rotate tires and see if it moves?
  3. Jan 19, 2025 at 8:31 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Probably tire or wheel bearing noise. If you eliminate tires by rotation and noise does not change, try jacking the suspect wheel and spinning it by hand. Compare to other side.
  4. Jan 20, 2025 at 7:40 PM
    wncsellers
    Wesley
    I feel silly for not trying this already. Will report back when the snow clears.
  5. Jan 23, 2025 at 6:35 PM
    Ahdofu
    Ahdofu New Member
    Matt
    My guess is wheel bearing
  6. Jan 23, 2025 at 6:42 PM
    wncsellers
    Wesley
    Haven’t gotten the chance to rotate tires and check noise again, but I’m hoping that clears it up. My truck isn’t in the best condition and I don’t want to spend wheel bearing time and money
