Weird Rattle noise lower engine
Discussion in '5th Gen 4Runners (2010-2024)' started by Crossfit4Runner, Dec 15, 2020.
  1. Dec 15, 2020 at 3:07 PM
    Crossfit4Runner
    Crossfit4Runner [OP] New Member
    Saint Louis
    2018 TRD Off Road Permium
    To many to list
    I get a weird rattle noise coming from the lower engine area while idling and accelerating from a stop. It sounds like a bolt rattling in a metal pan. It’s not a all the time thing and goes away with in seconds or accelerating.
    I’ve gotten under and checked all the shields, skid plates etc and I can’t find a thing. I’ve done a lot of mods and checked to make sure everything is correct and right.
    Any help where I can start looking would be greatly appreciated.
  2. Dec 15, 2020 at 5:37 PM
    Would it be possible to catch a video or audio of this? The 4.0 is a noisy motor. It might not be a problem.
    I did get a rattling once when a small rock was in the skid plate and vibrating against the exhaust at low speed.
    Toy4X4 and Crossfit4Runner[OP] like this.
  3. Dec 15, 2020 at 6:08 PM
    Crossfit4Runner
    Saint Louis
    To many to list
    Yes I’ll try again. Since it not a all the time thing and I usually hear it when in a drive though and such. It’s difficult. Since I have 60k on it I’m used to the normal engine noise and this isn’t normal.
  4. Dec 15, 2020 at 6:13 PM
    Ok. Just wanted to make sure you were familiar with the lifter noise. :)
    Now, I'm curious! Hopefully it's something simple. :homer:
  5. Dec 15, 2020 at 6:17 PM
    Crossfit4Runner
    Saint Louis
    To many to list
    Yeah me too. It almost sounds like something is loose rattling. It’s a Metal on metal sound
  6. Dec 15, 2020 at 6:21 PM
    Maybe a heat shield on the exhaust, or loose bolt in a skid plate. I know that crossover pipe on the exhaust likes to rattle.
    Subbed for other ideas, and conclusion.
  7. Dec 16, 2020 at 7:16 AM
    MAXIM
    MAXIM New Member
    Pebble on skid plate?
  8. Dec 16, 2020 at 8:26 AM
    Crossfit4Runner
    Saint Louis
    To many to list
    Nope I took it off to double check. I got a recording I’m trying to upload but it says that I don’t have the right extension
  9. Dec 29, 2020 at 1:03 PM
    Crossfit4Runner
    Saint Louis
    To many to list
    Well I finally got to the bottom of my noise. It appears to be my exhaust. I finally got to hear it when I wasn’t driving and was able to get underneath it while it was making it. I replaced my stock one with the Pro Exhaust so I’m assuming either I missed something or it’s binding some how.
  10. Dec 31, 2020 at 8:15 AM
    Crossfit4Runner
    Saint Louis
    To many to list
    Apparently it’s coming from this connection. It came with a new gasket which I replaced. So I’m not sure what i did wrong.
  11. Dec 31, 2020 at 8:19 AM
    ipnpulz
    ipnpulz New Member
    2023 TRDOR premium T4R
    I had a horrible knocking noise from my engine as my fuel pump went out on my 19 T4R
    Crossfit4Runner[OP] likes this.
  12. Dec 31, 2020 at 8:24 AM
    Crossfit4Runner
    Saint Louis
    To many to list
    Interesting I’ve been following the recall and people have also mentioned loosing gas mileage which I have noticed also.
  13. Dec 31, 2020 at 8:29 AM
    ipnpulz
    ipnpulz New Member
    My Mileage per tank and MPG's tanked bad right before it went out
  14. Dec 31, 2020 at 8:31 AM
    Crossfit4Runner
    Saint Louis
    To many to list
    I just checked I’m not on the recall
    ipnpulz[QUOTED] likes this.
  15. Feb 23, 2021 at 4:49 PM
    Crossfit4Runner
    Saint Louis
    To many to list
    Turns out the gasket went bad. Lucky I kept all the old stock exhaust parts when I installed the pro exhaust and reused the old one. I noticed that the original one was a lot beefier than the one that came with the Pro exhaust. I should have just reused the old one at the time and saved myself some trouble.
    SmurFJ and doublewide like this.
  16. Feb 24, 2021 at 6:45 PM
    SmurFJ
    SmurFJ New Member
    Bryan
    2021 Lunar Rock Pro
    My FJ had the same noise caused by the same thing. Replaced the gasket and all is quiet again
