Water??
Discussion in '5th Gen 4Runners (2010-2024)' started by Swamprat16, Mar 5, 2024.
  1. Mar 5, 2024 at 3:53 PM
    Swamprat16
    Swamprat16 [OP] New Member
    Cole
    2011” 4runner
    None
    We had a good rain the other day, and my 4Runner was leaking water onto the driver side floor from behind the plastics at my shins?? Anyone had this happen?
  2. Mar 5, 2024 at 4:04 PM
    Do you have a moon roof? I've heard of the drains clogging and water getting in. But, that sounds like an odd place for it to come in.
    Swamprat16[OP] likes this.
  3. Mar 5, 2024 at 4:11 PM
    West Coast, Sierra Mountains
    The only vehicle I've ever owned that had a similar instance was a 72 T-Bird...caused by a door seal leak. Wouldn't hurt to take a close look at the seals on your door.
  4. Mar 5, 2024 at 4:19 PM
    Swamprat16
    Cole
    2011” 4runner
    None
    I do have a sunroof but it wasn’t wet anywhere around there
  5. Mar 5, 2024 at 5:08 PM
    I’d still check the drains if I could.
    Anything else change lately like windshield replacement?
    Did you feel all over? Maybe opening a door and peeling back the weather stripping could show you dampness that might not be apparent.
    Otherwise I’d run my hands all over the place up and down just to be sure.
  6. Mar 5, 2024 at 5:15 PM
    I would run some weed whacker line down the moon roof drain holes first, and go from there.
  7. Mar 6, 2024 at 4:34 AM
    MikeS
    MikeS New Member
    Kemptville, Ontario
    2019 TRD Off-Road
  8. Mar 6, 2024 at 5:13 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Compressed air?
  9. Mar 6, 2024 at 6:13 AM
    Swamprat16
    Cole
    2011” 4runner
    None
    So I do believe it’s my sunroof. It wasn’t wet where it was before. But it really sucks cause the water is getting into my little console thing where the a-trac, traction control, and DAC buttons are and it also somehow effete my head unit. It turns off when this happens. But I’m thinking it’s running all the down the pillar all the way to my feet..
  10. Mar 6, 2024 at 7:35 AM
    All moving glass on your vehicle are basically controlled leak paths. The moonroof has a water tray around the perimeter with 4 drain tubes, 2 of which run down the A-pillars. If the tube disconnected from its spigot or if the tube develops cracks, water will leak. This is a somewhat common issue on 4Runners and 3rd gen Tacomas.
