Water Spots Remover
Discussion in 'Detailing' started by Onapulitan, Aug 18, 2021.
  1. Aug 18, 2021 at 5:56 AM
    Onapulitan
    Onapulitan [OP] New Member
    So I hand wash my venture and hand dry it every tine but the problem
    I’m having is when the sprinklers go on they leave water spots all over and the few quick detailers I used are not working very good. What’s everyone using as a quick detailer to remove water spots
    Thank You
  2. Aug 18, 2021 at 10:50 AM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    on body or glass ?
  3. Aug 18, 2021 at 12:06 PM
    Onapulitan
    Body
  4. Aug 18, 2021 at 1:12 PM
    DogStar84
    DogStar84 New Member
    sprinkler water spot removal can be tough. if left on too long, they can etch and be close to permanent.
    mine were baked on good on dark colored car,
    Had to machine buff off with a cutting compound. then wax over top. Even then, it wasnt perfect but huge improvement
    get off early with random orbital buffer, then wax/silicon car so easier to remove in future. good luck
  5. Aug 18, 2021 at 3:30 PM
    BeavertonCommuter
    BeavertonCommuter New Member
    Are the sprinklers yours? Is money an issue? If Yes and No, you might try a water softener to your sprinklers. Thats a long-term solution.
    Another medium-term solution is a ceramic coating which I think will resist the etching that can accompany a variety of substances that land and stick to the surface like bird droppings, tap water, etc.
    Short-term...any quick detailer will work provided you get to it soon, i.e., before its gets hot and baked on. But you also have to be careful, too, when using that approach to avoid scratching the clear coat. This approach works well when the vehicle is cool and relatively clean.
  6. Aug 18, 2021 at 7:47 PM
    DogStar84
    On my dark blue car it did etch the clear coat. A buff and wax improves it but a shame I t will never look great again
    They are my sprinklers so its all my fault.
    I have a 21’ MGM tacoma. Its garaged but I should try that ceramic coating stuff now whens its new.
  7. Aug 18, 2021 at 9:44 PM
    BeavertonCommuter
    You might join the autogeek forum, I recall seeing several threads there dealing with car paint and sprinklers.
  8. Aug 19, 2021 at 9:20 AM
    DogStar84
    Thanks, need to try that next time I tackle the water stains. I just watched a couple of toyota YouTubers ceramic coat their trucks.
  9. Aug 20, 2021 at 12:28 AM
    dricko
    dricko New Member
    Derick W.
    The CarPro Spotless is a good product also.
