Warning lights: Multi-terrain Seleft and Four-wheel Indicator lights flashing
Discussion in '5th Gen 4Runners (2010-2024)' started by robkh1984, Jun 4, 2019.
  1. Jun 4, 2019 at 9:37 AM
    robkh1984
    robkh1984 [OP] New Member
    Rob
    2016 4Runner Trail Edition Premium 4x4 Magnetic Grey
    To my friends and 4Runnertiers! :hattip:
    I have a 2016 4Runner Trail Premium and have been going nuts looking up and down this (and other forums), mechanics manuals, and I may have finished the web at this point. :smashpc:
    I come to you with humility and a sense of pride that someone on here may have an answer or various answers I can test out. :bowdown:
    The Multi-terrain Select Indicator and Four-wheel drive indicator lights are flashing. The first slower than the second, but both flashing. :dancingbroccoli::dancingbroccoli:
    Here's what I've tried so far:
    • Put the 4wd mode selector to 4Lo. Drove in Reverse for 100+ ft. Also drove forward for 100+ ft Did the same for 4Hi. Tried this a few times over. No luck.
    • Checked the fuses, both in the car cabin and in the engine bay.
    • Scanned and cleared any and all codes a few times using a BlueDriver Bluetooth OBD2 scan tool.
    A few questions:
    1. Could it be a relay? If so, which one?
    2. One of the wires loose on the ABS or other sensors?
    3. Traction control messed up?
    4. Any relation to a parking brake bypass switch I've added to my aftermarket stereo (Pioneer AVIC8200-NEX)? I've had the switch for a while, but fiddled around with the radio and wondering if there's any causation.
    5. Related to the Pedal Commander I use?
    Many thanks in advanced!
    Rob
  2. Jun 4, 2019 at 10:30 AM
    What codes are you getting?
    Clearing the code is not fixing the problem.
    robkh1984[OP] likes this.
  3. Jun 4, 2019 at 11:03 AM
    JBTRD
    Jeremy
    Ohio
    2016 (The Real) Trail Edition
    Its a speed sensor, most people have had this issue. They are a weak point and allow lots of build up of dirt damaging a sensor. It is usually the ABS speed sensor. Mine was the one on my transfer case.
    robkh1984[OP] and Oey12 like this.
  4. Jun 4, 2019 at 11:51 AM
    Oey12
    Oey12 New Member
    Joey`
    2017 SR5
    Eibach Pro Sport leveling shocks, Firestone airbags, and Baja Design fog lights...
    This would be my bet... I had the exact same issue you had OP, and it was a wheel speed sensor. I had no 4x4/traction control/crawl controls and then a snow storm hit... The Toyota tech said they are very weak and break pretty much by doing any suspension work and dirt.
  5. Jun 4, 2019 at 2:00 PM
    robkh1984
    Rob
    Funny part was that I didn't get any codes.
  6. Jun 4, 2019 at 2:04 PM
    robkh1984
    Rob
    Thanks! Wonder if I touched it when I added the CBI front and rear skid plates a few weeks ago, even though the warning lights didn't come on until recently. I have the skid plates off now (to add protective coating), and can probably see better.
    Ir assume there multiple speed and/or ABS sensors? Can you tell through a visual inspection if they're not working or would I need to do a voltameter or something?
  7. Jun 4, 2019 at 2:22 PM
    robkh1984
    Rob
    toy33 likes this.
  8. Jun 4, 2019 at 2:24 PM
    robkh1984
    Rob
    Braves95 likes this.
  9. Jun 4, 2019 at 4:55 PM
    Braves95
    Braves95 New Member
    David
    2019 Nightshade Special Edition MGM
    None Yet!!
    robkh1984[QUOTED][OP] likes this.
  10. Jun 4, 2019 at 5:26 PM
    Oey12
    Oey12 New Member
    Joey`
    2017 SR5
    Neither did I...but the dealership did some other test and diagnosed it very quickly.
  11. Jun 5, 2019 at 9:19 AM
    robkh1984
    Rob
    Just dropped it off to the dealership in Sunnyvale, CA. I've had them work on stuff before, so let's see how it goes. Good time for that airbag recall too
  12. Jun 5, 2019 at 10:48 PM
    robkh1984
    Rob
    Dealer chased down the wiring and signals and found some of the wires for the front differential actuator cut somehow. Wtf?!?!? They're going to solder and reconnect them again and check again. IMG_1798-01.jpg
  13. Jun 6, 2019 at 2:35 AM
    Braves95
    Braves95 New Member
    David
    None Yet!!
    Wow!! Where is that located?
  14. Jun 6, 2019 at 7:45 AM
    robkh1984
    Rob
    That's the view looking from the rear passenger side, near the transmission oil pan.
  15. Jun 6, 2019 at 7:56 AM
    Do you think rats or mice could have done that?
  16. Jun 6, 2019 at 9:15 AM
    robkh1984
    Rob
    Honestly, not sure. I'd assume rodents would prefer the engine bay where it's warmer, but who knows?!?!
    I'm wondering if any of the steel skid plates I added would have nipped it during install or if I hit something while driving. The wires face forward, which make it susceptible to being damaged by oncoming objects, much like how the ABS Speed Sensors wires are vulnerable.
    Dealer is estimating 3 hours of labor (@ $200/hr!!!) to solder the wires, adding some additional length to give it a bit more slack in case the wires caught on something.
    I can't wait for my skid plates to be done from the powderc shop. I'll be picking up the SDHQ ABS sensor guards too.
    SlvrSlug[QUOTED] likes this.
  17. Jun 6, 2019 at 12:02 PM
    Well it doesn't look clean cut so I think either something hit it and cut or was rats.
    7385 likes this.
  18. Jun 11, 2019 at 1:06 PM
    robkh1984
    Rob
    Circling back with the group. I'm $600 lighter in the wallet, but the problem seems to be fixed. Here's a summary from the dealer...
