VSC OFF, Traction control off, and VSC TRAC lights all on
Discussion in '4th Gen 4Runners (2003-2009)' started by aquachicken597, Jul 28, 2022.
  1. Jul 28, 2022 at 2:38 PM
    aquachicken597
    aquachicken597 [OP] New Member
    Jamie
    2006 4Runner Limited V8
    I have a 2006 4Runner with the 4.7L, and all of these lights are on my dash. I've tried doing the reset with the OBDII, but that didn't work. Any recommendations?
  2. Jul 28, 2022 at 3:00 PM
    Did you read the codes?
    No check engine light with those means that there is something wrong with the Vehicle Stability Control.
  3. Jul 28, 2022 at 3:01 PM
    aquachicken597
    Jamie
    Yes there is a CEL, but they have to do with the air injection system. I'm doing the bypass soon.
  4. Jul 28, 2022 at 3:03 PM
    Why didn't you say that?
    CEL will turn those lights on. Get the CEL to turn off and those should go away. TOYOTAs, when you have an engine issue, disable the traction systems for safety.
  5. Jul 28, 2022 at 3:05 PM
    aquachicken597
    Jamie
    Oh gee willikers! Yeah sorry. Just purchased it, and I'm trying to fix all the little things. P0142, P0418, P2445. Thank you!
  6. Jul 29, 2022 at 9:23 AM
    iamincrediboy
    iamincrediboy New Member
    Central MD
    the SlyFox bypass or Hewitt tech?
  7. Jul 29, 2022 at 9:30 AM
    aquachicken597
    Jamie
    I went with the Hewitt Tech. Placed the order yesterday, so hopefully it arrives at a decent time.
  8. Jul 30, 2022 at 12:57 PM
    iamincrediboy
    Central MD
    Everything in the engine bay is mostly easy. Actually drivers side blockoff plate is a bit of a bitch. Best way i found was backing out the bolts, squeezing something thin in between the flanges and getting the plate in between, THEN sliding it into alignment. Just trying to shove it in place is not awesome. In the cab be sure to do some really good soldering at your ECU wires or else you will still show codes and engine act up... ask me how I know. And no, just using 3M splicing connectors is not adequate enough... ALSO ask how i know lol.
  9. Jul 30, 2022 at 1:03 PM
    aquachicken597
    Jamie
    Thank you for the tips! I will refrain from asking how you know haha. I can connect those dots.
  10. May 13, 2023 at 10:45 PM
    360runner
    360runner New Member
    Easton
    2007 Sport / 2023 ORP
    I had a solid mechanic in Washington who knew toyotas like ive never seen before. After the dealership failed to identify this same issue on my vehicle, it turned out to be a driver side rear wheel speed sensor. he pulled one from a junk yard and got rid of a two year eye sore. Hope this helps
  11. May 14, 2023 at 6:31 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    From the lights , id say its a wheel speed sensor as well.
  12. Jun 21, 2023 at 8:20 AM
    Vart69
    Vart69 New Member
    03 4Runner, grey
    go to youtube and look up Toyota 4Runner- reset VSC lights. See bullseyenate 231's video
    Is a quick fix. Your OBDII tripped it. its called a zero point cal.
  13. Jun 21, 2023 at 8:31 AM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    Correct, this is pretty much guaranteed to require a Zero Point Calibration. Posts about how to do it here on the forums.
