Vibrations after lift kit. (Solved)
Discussion in '5th Gen 4Runners (2010-2024)' started by Bobbybustle, Oct 6, 2018.
  1. Oct 6, 2018 at 4:09 PM
    Bobbybustle
    Bobbybustle [OP] New Member
    Bobby
    Classic Silver '16 TEP
    Toytec "3 lift
    Welp, I got a little vibration between 20 and 45 mph. Here's the story so far, and what I'm doing next...
    Got the runner a few weeks ago and threw on Toytec's 3" Bilsten lift as well as some Total Chaos UCAs. I noticed the vibes right after the install. These vibrations are similar to the growl that you get from a set of agressive MT tires. I'm still on the factory wheels and tires. The vibrations go away when shifted into 4Hi. I didn't drive it again until it went in for an alignment. The alignment didn't make it better.
    After some research on TW, it seems that the Tacoma guys have dealt with the exact same issue. I guess its a diff needle bearing on the driver's side that's experiencing too much radial load due to the increased angle of the CV shaft. The fix (for some) is to swap the needle bearing out for a bushing. So I went on the ECGS website, out came the credit card, and now I'm waiting for the bushing kit to ship to me. It doesn't seem like a huge chore, but I was kinda hoping that someone on here has done this job on a T4R and could offer a little advise. Thanks in advance.
  2. Oct 6, 2018 at 5:44 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    its hit and miss for the runner some say they have the issue (myself included) other no problem. the fix goes all over too. 4 some its aftermarket wheels some say diff spacer. others have done road force balancing and wheel has to be balanced with back spacing flange. mine never really went away but the road force helped. for me it's so nominal that I can take it or leave. best of luck with yours
    Bobbybustle[OP] likes this.
  3. Oct 8, 2018 at 3:07 PM
    Bobbybustle
    Bobby
    Toytec "3 lift
    Some compelling evidence.
    ruiz4251 likes this.
  4. Oct 9, 2018 at 5:35 AM
    Dreaded_Marauder
    Dreaded_Marauder New Member
    Ecgs took care of my problem on my 16 Tacoma after I lifted it. Getting the tool in was hard. I had to shave a tiny bit off one side so I could slip it in between, you’ll see what I mean when you do it. Make sure you get out a complete bearing. Had a couple pieces break off. Stick a grocery bag in the diff, worked for me. When you put the sleeve in make sure it’s straight before you start pounding on it. Rent a bearing install kit if you don’t have one.
  5. Oct 9, 2018 at 7:34 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    yes that needle bearing in the front diff with your lift . post back how it worked out ..
    vibs are a PITA to find ... on ALL vehicles ...
    Bobbybustle[OP] and LostHusker like this.
  6. Oct 9, 2018 at 8:45 AM
    brochacho
    brochacho New Member
    2018 Sequoia TRD Sport
    ECGS bushing took care of my vibes on my Tacoma. I had no issue with my 4Runner though. I think I still have the special tool, if you are interested shoot me a PM.
  7. Oct 9, 2018 at 1:43 PM
    Bobbybustle
    Bobby
    Toytec "3 lift
    Success! The bushing is in and the vibes are gone. The install went smooth and without issue. Well, there was that fireant that crawled up my pants and bit the back of my sack, but other than that, perfect. If you look at the bearing, it's pretty easy to see that the shaft was actually riding on the cage as well as the rollers. Kind of a shit design if you ask me. I'm glad I didn't ignore it.
    Another thing was that my front diff was way low on fluid despite it having the factory paint marks on the plugs. Less than a qt. came out and a little more than 1.5qts went in.
    Thanks for all the advice, everyone. It really helped!
    :yes:
    Oldtoyotaguy, siblue, jgcaps and 4 others like this.
  8. Oct 9, 2018 at 3:56 PM
    j cat
    j cat New Member
    massachusetts
    thanks for your posting on this .. great info.. @3K miles I did inspect all the fluids .. all looked perfect except for the rear diff..
    many do get the free oil changes , but many dealerships do NOT inspect all the drive train fluids ...so with low diff oil that would damage the bearing ..
  9. Oct 9, 2018 at 3:58 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    update in a few weeks bud. gonna have to do this. thanks
  10. Oct 9, 2018 at 4:45 PM
    Bobbybustle
    Bobby
    Toytec "3 lift
    For sure. I have pretty long road trip coming up this week. Some 2000 miles round trip. I'll check back if anything pops up.
  11. Oct 9, 2018 at 6:08 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    good luck on the trip man. hope yall have fun
  12. Oct 9, 2018 at 8:37 PM
    Bobbybustle
    Bobby
    Toytec "3 lift
    The plastic bag is an excellent tip. I was lucky enough to get the bearing out in one piece, but I would have definitely been frustrated had I lost some shrapnel into the diff.
  13. Oct 9, 2018 at 8:43 PM
    Bobbybustle
    Bobby
    Toytec "3 lift
    Yeah, I'm def gonna uncork the other drivetrain components tomorrow just to make sure.
  14. Oct 17, 2018 at 11:18 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    how'd the trip go bud?
  15. Oct 17, 2018 at 11:25 AM
    Bobbybustle
    Bobby
    Toytec "3 lift
    I'm about 60% into my road trip and have covered around 1200 miles. From Southeastern New Mexico, visiting some good friends in Phoenix, then a long weekend in LA and game 3 of the NLCS, and now Im visiting my Mom in Porterville, CA.
    The 4runner has been running great. No vibrations or oil leaks. So far so good. My only minor complaint is that the suspension is a bit stiff for LA's 100 year old freeways. Maybe if I could drive them faster than 7mph, then the suspension would have soaked up the potholes better.
    All together I'm happy.
    Stgo likes this.
  16. Oct 17, 2018 at 11:26 AM
    Bobbybustle
    Bobby
    Toytec "3 lift
    Haha, I was just checking back.
  17. Oct 17, 2018 at 12:59 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    sounds like a kick ass trip man. enjoy the rest of it.
  18. Oct 17, 2018 at 1:54 PM
    topdec
    topdec New Member
    2023 4R ORP CSM 2023 Tundra LTD ORP. 2016 4R TE (sold)
  19. Oct 17, 2018 at 3:12 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Cali lol,... i choked on my own spit, and blew a snot bubble outta my nose , snorting/laughing at this......
  20. Oct 19, 2018 at 7:54 PM
    Dreaded_Marauder
    I just drove from Vegas to San Louis Obispo and the freeways felt like a roller coaster ride haha.
  21. Oct 19, 2018 at 9:05 PM
    4runningMan
    4runningMan New Member
    New Mexico
    It is a poor design imo. I don't know why they don't just use one like the ecgs. Must be a good reason, though.
  22. Jun 28, 2020 at 1:38 PM
    Bobbybustle
    Bobby
    Toytec "3 lift
    Update! So here we are 20 months later and the drivetrain is still vibration free. I did have tire issues tho. A month or so after my last post here I put 5 Nitto Ridgegrapplers on it, 285/70/17's. I had a nasty vibe at speed in the steering wheel. I rotated the tires and the vibes moved to the back. So in I went for a balance job with no joy, same problem. Then I had a Tanaka airbag campaign letter and since it had to go to the dealer anyway, I asked Roswell Toyota if they had a roadforce machine. I got her in there and sure enough, thegthe roadforce machine detected a bad tire. I asked them to swap it for my spare and the spare balanced perfectly. I've been vibration free since then and was able to warranty claim the one bad tire bc I had barely put any wear on it.
    I guess I should feel lucky that I've been able to pinpoint my vibration problems pretty quickly. Having been a Jeep owner previously, I know how hard it can be to troubleshoot sometimes. But thanks again to all of you for the great advice and positive vibes! :rimshot:
  23. Jun 28, 2020 at 7:34 PM
    I had the same needle bearing issue pretty much right off the showroom floor. I took it in right before I did my lift and got a new front differential under warranty. If I have a problem again, I'll do the EGCS bushing.
    Bobbybustle[OP] and 7385 like this.
  24. Jul 11, 2020 at 8:54 PM
    Grandmasteryoda
    Grandmasteryoda New Member
    Glad to find this post. Was looking for all the info I could get in one place on vibration.
    WTW15 and Bobbybustle[OP] like this.
