Very low voltage at starter signal wire
Discussion in '1st Gen 4Runners (1984-1989)' started by YotaHounds92, Aug 26, 2025 at 11:11 AM.
  1. Aug 26, 2025 at 11:11 AM
    YotaHounds92
    YotaHounds92 [OP] New Member
    Tuesday
    1987 4runner
    1987 4runner with a 22re and 5 speed. Had a no crank, no start problem when I bought it. Previous owner had an automotive 40 amp relay in place of the original starter relay, but it wasn't wired correctly. I wired it up and it fired right up. I've been slowly working on this rig whenever I have time and it's always fired right up. Now, it won't crank over. Just like what it was doing when I acquired it about a month ago. I found factory starter relay and wired it in according to how I've seen it on this forum. Still nothing. New battery, alternator, and starter. I've redone the grounds. I tested the battery cable going to starter and it's at 12.8 volts, the smaller wire that connects to the starter isn't reading any volts, earlier today it was reading .002 volts on my multimeter but now it's at 0. I'm not good at electrical stuff so I need some help....thanks in advance for any suggestions, tips or advice.
  2. Aug 26, 2025 at 5:13 PM
