Valve cover replacement
Discussion in '2nd Gen 4Runners (1990-1995)' started by Jbruce243, Mar 22, 2022.
  1. Mar 22, 2022 at 1:22 PM
    Jbruce243
    Jbruce243 [OP] New Member
    Justin
    1993 Black 4Runner
    Sound system, led light bar, normal maintenance and repairs
    Currently replacing valve cover gaskets, the driver side went on perfectly but when I got to the passenger side I can’t seem to get the holes to line back up. I’m curious if its because the gasket isn’t on properly, which it looks like it’s on properly or it’s something else but if anyone has any tips or tricks to line the holes up it would be greatly appreciated
  2. Mar 22, 2022 at 3:46 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Well it is either the gasket or the cover. Did you try turning the cover around? If you did then it is most likely the gasket.
  3. Mar 22, 2022 at 10:05 PM
    Jbruce243
    Justin
    1993 Black 4Runner
    I was able to get it on, there was some gasket sealer from the old gasket still on the surface, just needed to do a little more cleaning and it lined up. I’ll be firing it up in the morning to see if anymore oil leaks from around the cover
    trlhiker likes this.
  4. Apr 29, 2022 at 4:13 AM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    Use the Feld Pro rubber gaskets they fit the cam covers better than the silicon ones do and seem to be a bit thicker than the other brands. The CAM plugs at the back of the heads are prone to spew if they are not seated and clamped by removing and replacing the rear cam bearing cap as that makes for the best means in getting the gasket maker to squirt evenly about the entire outside diameter of the plug as you draw down the cam bearing cap with Loctite 515 on the surfaces to seal the cap to the head. RightStuff on the plugs surfaces seems to provide the best seal on the plug. I put silicone gasket in my cam covers when I did my engine rebuild and they were leaking within 10K miles. I am at 20K now and just installed the Feld Pro gaskets so we will see how they work out ,fingers crossed that I have found the solution!
