v8 too many miles?
Discussion in '4th Gen 4Runners (2003-2009)' started by afuller, Jul 26, 2021.
  1. Jul 26, 2021 at 7:11 AM
    afuller
    afuller [OP] New Member
    Knoxville
  2. Jul 26, 2021 at 9:28 AM
    4thgenV808
    4thgenV808 New Member
    2004 V8 4X4 & 2018 Tacoma TRD Pro (Manual)
    I would be more worried about frame issues than engine issues. Check the timing belt but these engines will run twice that easy if taken care of. Overall hard time to get a good price on used vehicles with all the shortages going on.
    RonT4R and Thatbassguy like this.
  3. Jul 26, 2021 at 9:32 PM
    spencermarkd
    spencermarkd New Member
    Spencer
    Pullman, WA
    2007 Driftwood Pearl SR5
    Thats suspiciously cheap.
    If the timing belt as been done regularly the engine should be fine. And like @4thgenV808 said, I'd be taking an extremely close look at the frame underneath. Check inside the rails near the engine and trans mounts for it flaking away.
    4thgenV808 and Thatbassguy like this.
  4. Jul 27, 2021 at 7:37 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Long as you can see it first hand or get pictures/verification, check:
    -maybe most specifically for rust check front passenger side frame right inside wheel well where the body mount is, as the ac condensate drains literally right onto the frame right there
    -exhaust manifold both sides for excessive rust/cracking
    -timing belt/water pump/thermostat completion
    -look at steering rack u-joint for excessive play and any leaking oil
    -video of ac compressor engaging with sound to verify clutch/bearings are not gone
    -any maintenance records on fluids changes, namely transmission and transfer case (if they have what the fluids were even better)
    -check every door edge where the pinch in the metal is for rust
    -check sunroof drains for clogging
    -check rear hatch rubber button for degraded rubber - not super expensive just annoying to replace
    Without information on all that, and wayyyy more pictures than that ad provides, I would be HIGHLY suspicious of that price.
  5. Aug 11, 2021 at 2:03 AM
    dricko
    dricko New Member
    Derick W.
    If available, check the maintenance records also.
