Upper control arms
Discussion in '5th Gen 4Runners (2010-2024)' started by Djandjul, Aug 19, 2024.
  1. Aug 19, 2024 at 7:19 PM
    Djandjul
    Djandjul [OP] New Member
    Danny
    Northern California
    2023 trd off road
    3” lift, nerf steps, cat bak exhaust, tires and wheels
    Looking for recommendations on upper control arms, JBA seems to have good reviews, any advice?
  2. Aug 19, 2024 at 7:36 PM
    SPC gets my vote. Not too expensive and do the job. There is a video by Tinkers on this subject. He nails down the math and mechanics of this in a good way.
    Spare Parts likes this.
  3. Aug 20, 2024 at 3:03 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I’ve got JBA’s on my 2021 TRD OR along with a 2” lift using Dobinsons springs and Bilstein 5100’s. I’m able to get a very good alignment with this setup and am very happy with them.
    Cheers,
    Bob
    dani07april06 and Djandjul[OP] like this.
  4. Aug 20, 2024 at 4:18 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
  5. Aug 20, 2024 at 5:23 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I wouldn't recommend SPC personally unless you really need that adjustability. (You probably don't) https://www.4runners.com/threads/spc-uca-failures.31675/page-2
    JBA's are great but take proprietary ball joints. I went with Apache Off Road UCA's with OEM sized MOOG ball joints after my SPC's failed in less than a year.
    I'd recommend the Dobinsons UCA's. Those also use an OEM sized ball joint for easy replacement. Dobbies stuff is usually very good.
    https://exitoffroad.com/product/dob...cruiser-4runner-lexus-gx470-gx460-uca59-002k/
    Stoney Ranger and Nubes like this.
  6. Aug 20, 2024 at 10:22 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2023 4Runner TRD Off Road Premium
    ADD W1 Oil Catch Can. AFE Magnum FLOW Pro DRY S Air Filter. ARK Splash Guards. Baxter Performance TK-501-BK Oil Filter Adapter. Canvasback Back Hatch. Differential Breather Relocation. Diode Dynamics SS3 SAE Yellow Pro Fog Lights. Dongar Industries Adapter. DRL Mod Harness. Garmin Mini 2 Dashcam. Garmin Overlander. Bulletpoint RubiGrid Dash Mount. Overland Torque Tune. RokBlokz Mud Flaps. SAIS FIlter Mod. Stahlbus Oil Drain Plug. Yokohama Geolandar A/T4 G018 LT265/70R-17. Yota Xpedetion Pro Grille. Yota Xpedetion Valances.
    Dirt King
    Old Tanker and 1SilverRunner like this.
  7. Aug 20, 2024 at 10:28 AM
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    The SPC's my shop installed are sealed, so no maintenance unlike the previous design. I know a lot of folks had issues with previous SPC's so keep that in mind.
  8. Aug 20, 2024 at 11:00 AM
    For fitting larger tires, Dobinson billet arms are adjustable for camber, so you can crank the LCA cam bolts to maximize caster, then dial in camber with UCAs.
    SPC UCAs do the same thing, but the "Xaxis" pivot joints introduced around 2018 wear out fairly quickly (previous design with poly bushings, which I have, lasts a long time).
    1SilverRunner likes this.
  9. Aug 20, 2024 at 1:07 PM
    TRDSD
    2019 TRD Off Road Premium
    SPCs are made in China and their quality has suffered the last few years. Also harder to find techs who know how to adjust them properly for alignment if they're not familiar with them (unless it's a true off road shop). 2 good reasons to avoid. I run Dirt King tubular steel ones. They're great and take Moog-style replacement ball joints you can get anywhere. Made in San Diego.
  10. Aug 20, 2024 at 1:26 PM
    Are you sure about that?
  11. Aug 20, 2024 at 1:46 PM
    1SilverRunner
    Tejas
    I think both the SPC ball joints and MOOG Problem Solver ball joints are both made in China now...
    "Assembled In" doesn't mean much anymore.
    @TRDSD brings up a good point though. Most alignment techs are not going to touch any aftermarket components.
    Hell, most of them don't even dial in camber or caster properly. Most shops do a "Toe and go" alignment. Very frustrating imo.
    Both dirt king's tubular and apache off roads UCA's use the moog joints. They are pretty solid and can be found at most parts stores.
    I've abused my apache's with the MOOG joints and they're still rock solid.
    I believe the dobinsons tubular arms use Sankei555 joints (Toyota OE supplier)
    So if that's a big point of contention for you then go dobinsons tubular.
    If you NEED extra adjustment go with the billet dobinsons. But understand that most alignment shops will not touch them.
    TRDSD likes this.
  12. Aug 20, 2024 at 1:55 PM
    TRDSD
    VERY. It's well-known in the industry. See "COUNTRY OF ORIGIN" in the attached.
    "Designed, engineered, tested and assembled" is different than where it's actually made. SPC hides it now in careful semantics. Sorry to burst your bubble.
  13. Aug 20, 2024 at 1:57 PM
    We go through the same bs with our equipment at work.
    That is their bs way of saying we still get all the shit from other countries but we slap it together here in the USA.
    I only have experience with Icon and DO NOT buy. Unless you want constant squealing from the bushings.
  14. Aug 20, 2024 at 2:08 PM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: Hefty and Bud Built. Tires: KM3. Switchpro.
    "Designed, engineered, tested, and assembled". So they drew up the designs in the US. They did some sort of testing - maybe on the prototype, maybe on all, maybe a random sample. And they did some packaging and assembly. But their careful choice of those four words is a clear statement that the product is NOT manufactured in the US.
    Which explains why my SPC uppers failed and I ended up replacing them with Bilstein UCAs (which are manufactured by Dirt King I believe).
    TRDSD likes this.
  15. Aug 20, 2024 at 3:06 PM
    Agent_Outside
    Built 2011 T4R Limited
    Your not wrong, but this is slightly misleading.
    JBA proprietary ball joints are cerakoted high articulation ball joints with 90 degree range of motion - more than a uniball and without the noise and constant maintenance.
    However, you can replace them with an off the shelf readily available AC/Delco #45D0062, Raybestos #500-1062, or Moog #K6292 (used on GM trucks from 1988 to 1996) from any parts store and the balljoints don’t require any special tools to replace them.
    Gripster likes this.
  16. Aug 20, 2024 at 5:03 PM
    camburg, bilstein or OME
  17. Aug 20, 2024 at 5:10 PM
    Brownspotz
    Brownspotz High Class Hyena
    2022 sr5 4runner
    Upper control arms , ECGS bushing
    I'm satisfied with the jbas and 5100s My 4runner is a pavement princess so depending upon what your doing with it might sway your decision
  18. Aug 20, 2024 at 5:50 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    Be the rebel like me, and keep the factory UCA's. I've wheeled with guys that had 5Gen 4R's that were built way more than mine, and bailed at the trails I wanted to do. They were either too hard or too technical for their taste. The factory UCA's are severely under rated. I've been up Hell's Gate twice, and made it to Top of the World. Maybe I'm just too old and have the "if it ain't broke, don't fix it" attitude.
    Nick B, nimby, Toy4X4 and 2 others like this.
  19. Aug 20, 2024 at 6:34 PM
    Some can't get enough out of their alignment with stocks thats the main reason for changing them.
    Also since you are already under there makes sense to not need to go back.
    Rocko9999 likes this.
  20. Aug 20, 2024 at 6:38 PM
    Agent_Outside
    The strength of the arms is rarely the issue. It’s more the range of motion of the ball joint. There have been plenty of people that have over extended the the ball joint with downtravel resulting in a separation and catastrophic failure.
    Toy4X4 likes this.
  21. Aug 20, 2024 at 7:49 PM
    I kept the factory UCAs and the best they could do on alignment left my caster angles just barely out factory specs. It’s fine though…just makes the ride a little more spicy on the highway.
  22. Aug 20, 2024 at 9:42 PM
    kanye_asada
    kanye_asada New Member
    4 years / 30k miles later on my SPC, no issues.
  23. Aug 21, 2024 at 3:10 AM
    We went with the JBA's to get the caster adjustment range, plus I like the fact they are serviceable (grease fittings). We do not have a decent lift (suspension), just a spacer kit, but it's looking like Bilsteins are in our future. The JBA's have had some paint peel, other than that, seem to be OK, and gave us some room to adjust caster.20201222_095107[702]JBA UCA.jpg
  24. Aug 21, 2024 at 5:31 AM
    1SilverRunner
    Tejas
    That's very good to know! Thanks for the correction.
    I'm glad! Testimonials like that is why I gave them a shot. Unfortunately mine failed within a year after a few wheeling trips. SPC would not warranty the ball joints. When I contacted my local shop they suggested Apache or JBA. When I arrived they had a stack of dead SPC's in the corner of the shop. Apparently this was a common occurrence over the last couple of years. This experience is pretty well documented in the thread I cited in post #5 here. Because of this experience I don't recommend SPC to anyone.
    Still, I realize that some people have great luck with SPC. Hopefully yours hold up great.
  25. Aug 21, 2024 at 6:56 AM
    Hilborn
    Michael
    Utah
    New design Dirt King vs. Older design JBA.
    The older JBAs had the cup style seal that allowed water and dirt to enter and destroy the joints. JBA required me to run .75 wheel spacers with 17x8.5 with 4.75 BS.
    455038241_816404120663067_56668772325422_e88fee0d1bee6675a024e8ab03d4b622b8f9e374.jpg
    441497271_2303431093163725_4437343590047_84597fcea14493d176760486925a463f21b4fb6d.jpg
    Grug556 likes this.
  26. Aug 21, 2024 at 9:33 AM
    Dont always want factory specs.
    A lot want as much caster as possible and its not happening with stockers.
    Old Tanker likes this.
  27. Aug 21, 2024 at 9:42 AM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    Hey on the dirt king how often do you have to service or grease the ball? Is it like a EP-2 type standard grease? Any negatives to the dirt king?
  28. Aug 21, 2024 at 9:42 AM
    I’ve heard factory UCAs might be able to reach caster specs with lifts up to about 2inches. Makes sense, because mine was 2.5 in of lift, and my caster fell short about 0.2 degrees. Which isn’t horrible, and drives fine.
    Another positive with factory UCAs is that they will make it less likely for upsized 285/70-17 tires to rub on the body mounts. I’ve got no rubbing throughout the suspension range with my 285/70s on the factory OR wheels and stock mudflaps.
    dani07april06 likes this.
  29. Aug 21, 2024 at 9:50 AM
    TRDSD
    I would hope not. You’re barely driving it.
  30. Aug 21, 2024 at 9:53 AM
    Hilborn
    Michael
    Utah
    DK uses a Moog ball joint. I service mine with chassis grease every 5k.
    Grug556 likes this.
