Upgrading Limited's tires for aggressive look?
Discussion in 'Wheels & Tires' started by TennesseeRudy, Aug 1, 2023.
  1. Aug 1, 2023 at 9:48 AM
    TennesseeRudy
    TennesseeRudy [OP] New Member
    2015 Limited-Gray
    Modifications in process
    I've been reading through for 6 weeks and going bigger on tires is pretty complex. I'm hoping I can get pictures and help on what it took to get your Limited with the wheels and tires you needed.
    I have a 2015 4runner Limited with stock 20" rims. I'm wanting the tires to stick out (I think -18 offset is what I need) and go with a new 20" XD Rover864 -18mm offset. I'm also wanting to go with BFG KO2 285/55/R20's. I want that aggressive look with wide tire stance, but not crazy.
    Anyone else accomplish this on your Limited? Can you share what you had to do and pictures?
    I was thinking of only leveling, but a shop is telling me I need to lift 3 inches.
    Thanks
  2. Aug 1, 2023 at 11:29 AM
  3. Aug 1, 2023 at 11:32 AM
    Welcome to the forum.
  4. Aug 1, 2023 at 1:07 PM
    UofLCardfan77
    UofLCardfan77 Large Member
    Elizabethtown, Kentucky
    Welcome from the center of the bourbon universe.
  5. Aug 1, 2023 at 3:02 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Welcome!
    I agree that there is so much info on this forum, it makes everything confusing.
    I ended up buying what I wanted and just made the needed adjustment as I went
  6. Aug 1, 2023 at 3:13 PM
    Welcome!
  7. Aug 1, 2023 at 6:33 PM
    So far I have kept mine stock to see what the baseline is and have not changed anything as if yet.
    Welcome to the forum and set back and enjoy the ride!
  8. Aug 3, 2023 at 7:01 AM
    RetiredTRDowner
    RetiredTRDowner 2022 TRD Off-road Premium
    Fain
    Bella Vista, Arkansas
    Tint windows, replaced valences (black), 3x2 READYLIFT, Black Rhino Abrams (olive green) wheels, 185/70/17 Falken Wildpeak AT3 tires, AMP Power Running Board
    Welcome!
    I was told to fit 285/70/17 tires, that you needed 3x2 lift, loose front mud flaps and minor trimming of front fenders. This is what I did and added Black Rhino-Abrams (drab olive green) wheels (0 offset) & AMP power running boards.
    I like the look & I get a lot of compliments…
    Good luck on your decision!
    GO HOGS!!
    TennesseeRudy[OP] likes this.
  9. Aug 3, 2023 at 1:33 PM
    DesertSurfer
    Got a buddy in Nashville, great to have you aboard!
  10. Aug 3, 2023 at 2:00 PM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    Im not sure how different the limited trim is from a tire fitment and lift perspective but as others have noted if you want to go 33's (285 70 R17) you'll definitely need some trimming of the front fender liner and a lift (spacer or new suspension) can often help clear the tires
  11. Aug 6, 2023 at 12:50 PM
    TennesseeRudy
    2015 Limited-Gray
    Thank you all for sharing. I'm not going to be doing any offroading, truly want a good looking 4 runner with an aggressive wheel and tire stance where they show a couple inches outside the wheel well. I see the vast majority of people are going with 17" wheels is that because your offroading? Or is there something else the 17" gives you on the 4 runner thats better than the 20"? Just curious if I'm missing something.
