Upgrades
Discussion in '2nd Gen 4Runners (1990-1995)' started by Jay.puckett93, Mar 9, 2023.
  1. Mar 9, 2023 at 11:27 AM
    Jay.puckett93
    Jay.puckett93 [OP] New Member
    1990 4Runner 3.0 V6
    So question guys, I am new to the 4Runner life and just got my first one which is a 1990 4Runner 3.0 V6 and am wanting to make it an off-road rig. I’m planning on starting with a Lift of about 5 inches and attempting to put 35s under it.
    1st question would 35s fit with a 5 inch lift?
    2nd question lockers, do you guys run front and rear lockers or just a rear locker? I live in an area where there a lot mountains and snow.
    3rd Question where do you guys go to find your bumpers for the front and rear and rock sliders?
  2. Mar 10, 2023 at 9:27 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Welcome. Unless you plan on regearing, I would not go bigger than 33's with maybe a 3 or 4 inch suspension lift. If you really want to go 35's then you would probably want to SAS and regear it and go front and rear locker. Good luck.
    watermelonman122 likes this.
  3. Mar 10, 2023 at 10:55 AM
    Welcome to the forum.
  4. Mar 10, 2023 at 3:24 PM
    JEQ5173052
    JEQ5173052 New Member
    Jacob
    1994 Toyota 4runner
    Lifted, tires... in the process of restoration
    I got 33s on a 4 inch lift... ends up being almost 8 inches from stock heightScreenshot_20211220-203605_Gallery.jpg
    hossler1788 likes this.
  5. Mar 11, 2023 at 3:27 AM
    Welcome from Wisconsin!
    JEQ5173052 likes this.
  6. Mar 11, 2023 at 3:48 AM
  7. Mar 14, 2023 at 8:53 AM
    Jay.puckett93
    1990 4Runner 3.0 V6
    what do you mean SAS? And what gear should I run?
  8. Mar 14, 2023 at 11:52 AM
    watermelonman122
    watermelonman122 New Member
    Utah
    1994 4Runner SR5 3.4 V6 4wd 5spd
    Solid Axle Swap?
  9. Mar 15, 2023 at 9:15 AM
    trlhiker
    trlhiker Lazy Bum
    This. . Do your homework first before deciding on it. As for gearing, it all depends on what is there now. 2nd Gens came with either 4:56 or 4:88 depending on wheels size. How you drop your spare will tell you which you have. If you are lucky and have the exterior spare then it is 4:88. If you have the 4:88's you would probably be fine up to 35's. Keeping it at 33's would be even better.
