upgraded to Iphone 15 pro max - now carplay not connecting.
Discussion in '5th Gen 4Runners (2010-2024)' started by bk77459, Apr 10, 2024.
  1. Apr 10, 2024 at 6:11 AM
    bk77459
    bk77459 [OP] New Member
    Bryan
    Sugar Land, Texas
    2022 4Runner Limited
    Good morning.
    I recently upgraded to the Iphone 15 Pro Max and I can no longer connect to my stock infotainment center. The phone goes back and forth between wanting to charge/connect and not. Any thoughts/suggestions would be helpful. Thanks.
    Also looking into the wireless Apple CarPlay devices. I've seen a couple on the forum but I've also seen quite a few new devices online. Any suggestions?
  2. Apr 10, 2024 at 6:38 AM
    welcome
    bk77459[OP] likes this.
  3. Apr 10, 2024 at 6:40 AM
    bk77459
    Bryan
    Sugar Land, Texas
    Thank you. Happy to be here.
  4. Apr 10, 2024 at 6:47 AM
    Welcome to the forum.
    First suggestion would be to try a second cable after rebooting the phone to eliminate that as being a culprit.
    steelevo likes this.
  5. Apr 10, 2024 at 7:00 AM
    PointmanUSMC
    PointmanUSMC New Member
    Illinois
    2023 Black TRD ORP 4 Runner Bronze Rims
    Update your phone first and replace the cable before attempting the following.
    https://www.toyota.com/firmware-updates
    steelevo and bk77459[QUOTED][OP] like this.
  6. Apr 10, 2024 at 7:59 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Make sure you've deleted your old phone from the car's memory.
  7. Apr 10, 2024 at 8:12 AM
    bk77459
    Bryan
    Sugar Land, Texas
    I have turned off and rebooted my phone, switched cables and deleted my phone and reinstalled onto the infotainment unit. It's still not responding correctly (doing the same thing). I don't have a spare USB drive so I'll have to go purchase one to upgrade firmware. Always a little hesitant to mess with the firmware but I'm at a loss. Thanks
  8. Apr 10, 2024 at 8:41 AM
    Fu3lC3ll
    Fu3lC3ll I.Am.Limited
    Cris
    2024 Limited Wind Chill Pearl
  9. Apr 10, 2024 at 8:51 AM
    steelevo
    Utah
    Welcome. There a lots of great suggestions in here.
  10. Apr 10, 2024 at 1:44 PM
    welcome. I also use a 15 pro max, but don't have stock head unit and still had the problem.
    Catbrown357 has it right, make sure you delete ALL the connections you ever had with other phones and start new. And the wireless adapter isn't a bad idea, they work pretty well too. That way all connections go to the adapter and the headunit only ever sees the one connection.
  11. Apr 10, 2024 at 2:34 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Yep. When I got my 15 pro max, I obliterated any trace of my old 11 pro on every car (4R, Tundra, Audi S5) and had no problems connecting on both stock HUs and aftermarket HUs. I find this happens in a lot of the aircraft I fly if there are too many devices trying to connect. I have to delete several, or all sometimes, before my devices will connect. At least it's only once in my vehicles.
    Steely123[QUOTED] and steelevo like this.
  12. Apr 12, 2024 at 6:29 AM
    bk77459
    Bryan
    Sugar Land, Texas
    Thanks for your input everyone. It appears the culprit was the small USB A to USB C adapter I was using. I purchased a USB A to USB C apple certified cable ($2.99) on Amazon and it fixed the issue. I'm still considering an OttoCast (Netflix/Youtube) version as I spend a lot of time waiting in the 4Runner.
    java likes this.
