*UPDATE*VSC and ABS Lights are on, need help/advise
Discussion in '5th Gen 4Runners (2010-2024)' started by Porch Dawg, Apr 11, 2024.
  1. Apr 11, 2024 at 11:04 AM
    Porch Dawg
    Porch Dawg [OP] New Member
    2017 4 Runner Limited
    None, yet
    Good afternoon.
    While driving I had to suddenly brake hard to avoid someone cutting me off. After a few minutes I noticed my VSC light was on. When I stopped at a stop light it started blinking and the ABS light started flashing. The VSC light blinks 3 times, pause, blink three times, pause....
    I stopped and shut the car off for about 15 minutes thinking it may clear, nope.
    Any help is greatly appreciated, thanks.
  2. Apr 11, 2024 at 11:14 AM
    Something like this may take a trip to the dealership to diagnose, unfortunately. There are so many possibilities.
    Porch Dawg[OP] likes this.
  3. Apr 11, 2024 at 12:10 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Attach a scanner and see what fault codes it is showing.
    Disconnect the battery for 30 mins and reconnect to see if it solves the problem.
  4. Apr 15, 2024 at 7:51 AM
    Deep scan for codes. Maybe an ABS capable scanner will see it but there may be a code from the traction computer.
  5. Apr 15, 2024 at 10:29 AM
    Porch Dawg
    None, yet
    UPDATE.
    The ABS light went out after a couple hours. The VSC light is still on. The fuses are all good, tried the battery trick mentioned earlier, and three seperate scans to see what error codes came up. The codes were all random and nothing consistent. I did stop at a dealership and told them what was going on the, the service guy laughed and said it needed to be a Toyota specific scanner, not a general off the shelf tool, ok I can except that. Anyway, I'm.dropping the vehicle this evening when I get back in town and will wait to see what they say. I bee.dto get my 100,000 mile service done anyway.
  6. Apr 15, 2024 at 10:41 AM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    How is brake fluid level?
    Odd to happen after hard emergency braking.
    Maybe that high pressure found a weak spot in the system for you and now you just have to figure out where that is.
  7. Apr 15, 2024 at 10:47 AM
    Porch Dawg
    None, yet
    Fluid level is spot on. Had the system flushed right after I got the vehicle, it's still clear :)
  8. Apr 15, 2024 at 11:02 AM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    speed sensor maybe? I'd check on Tacoma World, I bet you might find some answers on there
    raimieb and Porch Dawg[OP] like this.
  9. Apr 15, 2024 at 11:06 AM
    Startrek
    Startrek New Member
    random codes sometimes of bad trans switch.
  10. Apr 16, 2024 at 12:46 PM
    Porch Dawg
    None, yet
    Ok everybody watching this thread for an update here it is. Just got off the phone with the service department, he said the brake booster has gone out and isn't holding pressure. To me this seems plausible from the initial problem I posted about. The part is $2300 from the dealer and I should have my 4runner back tomorrow (Wednesday)
    Before everybody jumps on the "highway robbery" campaign, I'm away from home and my tools, I'm 58 and well past my prime of smashing my knuckles to do it myself. Also if something else breaks in the process they can fix it. :)
  11. Apr 16, 2024 at 12:52 PM
    Sucks but cheaper than a new vehicle.
  12. Apr 17, 2024 at 7:04 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I'm 61 and I'm busting knuckles because I don't trust anyone to be very honest. I get tired of being filled with crap.
    djdaves likes this.
  13. Apr 17, 2024 at 7:13 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    You didn't accidentally hit you VSC button did you? If it's blinking 3 times and pausing it's trying to tell you something. If you have a owners manual it could help. Broken skid ABS speed sensor wire with make ABS, VSC, transfer case light come on. If hatch isn't shut completely, hazard lights, 4lo and something else will come on when you hit a bump. Things I have learned or it taught me. You can disconnect the battery for a couple minutes. I bought a Bluetooth scan tool and drive with it plugged in for $26 at the moment. It's easy to clear P0430 code when it pops.
  14. Apr 17, 2024 at 7:21 AM
    Porch Dawg
    None, yet
    I thought that also but when I pushed the button nothing changed. The downhill assets wouldn't turn on and there was another system that stopped working also but I don't remember what it was at the moment. I also noticed in the info screen of the instrument cluster the display no longer showed the position of the front tires. I tried turning the wheels from lock to lock to maybe reset the display, that didn't work. Hope replacing the part works.
  15. Apr 18, 2024 at 6:39 PM
    Porch Dawg
    None, yet
    So the 4runner is back up and running. The brake booster went out and caused all kinds of problems.
    Spare Parts and raimieb like this.
  16. Apr 19, 2024 at 6:15 AM
    ^Bad luck. The brake booster on all 5th gens is electronic and integrates the ABS unit, hence the expense. Thankfully it doesn't fail often in the fleet.
  17. Apr 19, 2024 at 6:34 AM
    jgalt
    jgalt New Member
    Yeah those hydroboost MC's are steep! I wonder why they went that way vs. a conventional diaphragm booster? Not enough vacuum? Btw, RWD 4R's don't have the hydroboost version, but rather a conventional diaphragm instead.
  18. Apr 19, 2024 at 6:42 AM
    Daddykool
    I'm with you there. I used to do all the wrenching on my vehicles, and now do virtually none. Life situations change, and stress can truly kill. AND, a brake booster replacement? I've never done that. THAT would be stressful even before starting. 20 years ago I'd be all for doing it myself. Today, I'm just not interested in learning to do something new that's that complex and carries big risks if I fail. It's $2300 for a reason, even if there's an element of 'robbery'. And if there's a problem with the repair, you have a dealership you can push back on to make it right.
  19. Apr 19, 2024 at 7:51 AM
    2WD 4Runners aren't real 4Runners so they don't count :p
    The electronic booster is for A-Trac, enabling full braking power to clamp a spinning wheel while you're on the gas (where intake manifold doesn't have vacuum to power a vacuum booster).
    Porch Dawg[OP] and jgalt[QUOTED] like this.
  20. Apr 19, 2024 at 7:58 AM
    jgalt
    jgalt New Member
    Yeah, but they make great station wagons! Thanks for the ATRAC/Vacuum connection! Makes perfect sense.
  21. Apr 19, 2024 at 7:58 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    I had a 2012 Tacoma TRD Sport AC 2WD. That truck was absolutely scary in a panic stop. The truck literally would not stop in a reasonable distance. I traded it for my 2015 Tacoma TRD Sport AC 2WD with brake boost. Massive difference in braking capability. This truck stops, and quickly.
