Unidentified error/beep when shifting from reverse to drive?
Discussion in '5th Gen 4Runners (2010-2024)' started by laceofbase, Apr 29, 2021.
  1. Apr 29, 2021 at 12:02 PM
    laceofbase
    laceofbase [OP] New Member
    2017 Black 4Runner Limited
    Occasionally, when I'm backing out of my driveway or a parking space and I shift from 'reverse' to 'drive', theres a loud beep and error light that comes on over in the speedometer area (it's so fast I cant see what the symbol is, and I cant reproduce it). Anyone else experience this? I could simply shift slower, but I'm concerned it's a problem. (photo not mine, but a good one to illustrate the error options)
    Vehicle is 2017 T4R Limited
  2. Apr 29, 2021 at 12:38 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    On the info screen in the middle - did any message show in conjunction with the yellow caution indicator?
    And welcome to the forum!
  3. Apr 29, 2021 at 12:44 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Nanny is lightening fast and if you're rolling backwards the least little bit and shift in to D, she'll know it and squawk at you. That's my best guess. fwiw
  4. Apr 29, 2021 at 12:58 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    Good thought... I'm going to check that this afternoon.
  5. Apr 29, 2021 at 1:13 PM
    I've experienced the same thing, at least the beep but don't recall the warning message.
    I believe what others have posted, shifting into drive to quickly while the car is still moving backwards.
    This is probably causing a mis compare between the wheel sensors and the shift selector.
    laceofbase[OP] and 2Toys like this.
  6. Apr 29, 2021 at 1:18 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    I believe it's actually the hill assist warning chirping at you right before it actually engages. The vehicle is still rolling backwards slightly but the gear position is in 'D', so it thinks you are rolling backwards down a steep hill.
    In my Crown Vic I slam the car from R to D to R at 5+ mph and it takes it like a boss. In the Explorers, doing that will stall the engine. The 4Runner won't stall, but it also won't exactly tolerate it Vic-style. Just stop before you switch gears. Why risk potential damage?
  7. Apr 29, 2021 at 1:24 PM
    Hill assist warning, that's probably it.
  8. Apr 29, 2021 at 3:00 PM
    celaw309
    celaw309 New Member
    Chris
    NY
    2020 MGM TRD ORP
    This has happened to me a few times. It's the hill assist probably.
    SendInTheCavalry likes this.
  9. Apr 29, 2021 at 3:21 PM
    6uam671_T4R
    6uam671_T4R New Member
    I got that beep and light awhile back BUT while I was driving and hit a bumpy spot in the road. Ended up being the hatch not closed properly.
    Just a thought in case it’s not the hill assist.
  10. Apr 29, 2021 at 6:28 PM
    TN_FunRunner
    TN_FunRunner Custom Title
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    Mine has done this a few times in this exact scenario and I think it’s the traction control. Probably not completely stopped in reverse before shifting into drive.
    laceofbase[OP] likes this.
  11. Apr 30, 2021 at 10:52 AM
    laceofbase
    No message that I've seen in that middle area, just the yellow indicator and a "squawk" as @Moon Landing accurately described it.
    And thank you! Long time lurker :)
    2Toys[QUOTED] likes this.
  12. Apr 30, 2021 at 10:56 AM
    laceofbase
    Sounds exactly right. I'll just slow my roll. :turtleride:
  13. Apr 30, 2021 at 10:57 AM
    laceofbase
    Thanks for the input, everyone! Sounds like it's user error and the T4R is just doing it's thing. Appreciate it!
    ThePnsh3r and SlvrSlug like this.
