Understanding alignment numbers
Discussion in '5th Gen 4Runners (2010-2024)' started by sr5premium4x4, Oct 8, 2021.
  1. Oct 8, 2021 at 10:19 AM
    sr5premium4x4
    sr5premium4x4 [OP] New Member
    Got the following alignment numbers for 2021 SR5 Premium.
    Just installed 2.5 inch eibach pro lift kit with no UCA
    Are these alignment numbers any good or requires UCA to fix anything.
    Did not notice any issue myself except stiff ride compared to stock shocks. Just got 400 miles in total so maybe I need to wait little longer to find any issues. But want to understand those alignment numbers.
    Attached picture.
    This forum is extremely helpful to me in choosing and installing Eibach and 285 KO220211007_170212.jpg
  2. Oct 8, 2021 at 10:49 AM
    kmeeg LionRunner
    No idea about alignment. Here's mine for comparison;
    Update -
    My setup is ELKA 2.5 suspension and SPC UCA.
  3. Oct 8, 2021 at 11:12 AM
    Dillusion New Member
    KYle
    About as maxed on caster you prolly get on stockers
    If you don't rub and don't plan to upsize you might be ok.
  4. Oct 9, 2021 at 5:11 AM
    sr5premium4x4
    Rubbing slightly on reverse full lock which I am planning to fix. I think mud flaps need to be removed and fender liner needs to be pushed.
    caster being slightly off(.1 degree) specified range cause any other issues?
