Undercoating
Discussion in '5th Gen 4Runners (2010-2024)' started by TRD Ted, Aug 4, 2023.
  1. Aug 4, 2023 at 1:11 PM
    TRD Ted
    TRD Ted [OP] New Member
    Does anyone have any experience with the “ValuGard” undercoating sold at some Line-X dealers? And if so any negative experiences and can recommend something better? Looking for something set-and-forget.
    Mully410 and JuliaGotta4x4 like this.
  2. Oct 10, 2023 at 12:56 PM
    lynnaray
    lynnaray New Member
    2023 TRD Off Road
    Hey just following up on this - did you get it done on your truck? I am considering the same undercoating.
  3. Oct 10, 2023 at 1:21 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    No. Fluid Film instead.
    Han4Run likes this.
  4. Oct 10, 2023 at 2:35 PM
    Ramrod88
    Ramrod88 4Runner on Corolla budget
    New Orleans
    22 TRD OFF ROAD
    Cosmoline
  5. Oct 10, 2023 at 2:38 PM
    Ramrod88
    New Orleans
    22 TRD OFF ROAD
    rickystl likes this.
  6. Oct 10, 2023 at 2:57 PM
    TRD Ted
    I never did, seemed kind of gimmicky. I’m just going to use wool wax or fluid film.
  7. Oct 10, 2023 at 5:17 PM
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    A thorough rustproofing and undercoating is not cheap and takes about 3-4 days. I have had this done on several T4Rs.
    They remove all wheels, including spare, exhausts, heat shields, running boards, skid plates etc. Then they thoroughly clean, wire brushing if necessary, any areas that need it. Then spray on undercoating, let it dry for 24 hrs. Then spray a rustproofing on all areas that can’t be undercoated, including inside the frame rails. Let it dry for 24 hrs. Then put back on all the stuff removed. Then spray undercoating or rustproofing on that stuff as appropriate and let it dry for 24 hrs. Then I go back every year or so for inspection and they touch up any areas needed. I just had this done to mine over the last week. $2600. Doing this in the past, as I drive on the beach a lot on the Outer Banks in NC, has paid off well as I have never had a rust problem. I also run thru a car wash with undercarriage wash twice as soon as possible after such driving and when roads are salted in my area.
    Any offer for rustproofing an/or undercoating that takes a day or less is only a feel good thing IMHO
    JuliaGotta4x4 likes this.
  8. Oct 11, 2023 at 5:16 PM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    I watched the video. My Brother had Ziebart done to his 1977 Ford Pickup when new. But in the 70's, Ziebart was really the only option along with cheap quality under coatings. But today, there are much better and less expensive options. And opinions will very.
    Personally, I've had good success with Krown, if you have a Dealer in your area. My 21' ORP just had it's 3rd application this past May. The under carriage still looks new.
  9. Oct 13, 2023 at 10:28 AM
    JuliaGotta4x4
    JuliaGotta4x4 New Member
    Julia
    2018 TRD Off-Road
    None
    @salvojimmy That information is so helpful. Thank you.
  10. Oct 13, 2023 at 11:05 AM
    Wow, that sounds like a very thorough job! I’m assuming the product is a paint/tar type coating if it needs to dry? It sounds like they are doing it right if they are taking all those steps to protect things that shouldn't be sprayed (like electrical connections, rubber boots etc), and using other types of product where needed.
    But I think taking a day to spray Wool wax or similar greasy product is much more than a feel good treatment. 99 percent of the grease products will stick for years, (or indefinitely if it gets saturated with dust/dirt). But yeah, it will still need regular touch ups in certain spots on every year or two.
    salvojimmy[QUOTED] likes this.
  11. Oct 13, 2023 at 11:31 AM
    salvojimmy
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    I was speaking of undercoating when I mentioned the time it takes to do it right and thorough. For example I had a quote from Linex to undercoat for $800 and 4 hrs. No way can that be a good job.
  12. Oct 13, 2023 at 12:56 PM
    Ah sorry, I was thinking of the word undercoating as any type product applied to the frame. Yes, I’d be terrified of a quick and dirty job that uses an asphalt/resin/rubberized etc product lol. It would be worse than “feel good”, because those would be the situations where you might get adhesion failure that allows water between it and the metal.
