"Unable to access USB flash drive - SOLVED!"
Discussion in '5th Gen 4Runners (2010-2024)' started by Richmond Dan, Sep 21, 2018.
  1. Sep 21, 2018 at 9:42 AM
    Richmond Dan
    Richmond Dan [OP] New Member
    Richmond, VA
    Picked up my TRD Off Road Premium two days ago. I formatted a small USB flash drive (FAT32), put three photos on there, and when I put it in the slot to upload to head unit I get the message above.
    The same flash drive works fine in my RAV4. Before I take 4Runner in for service (seems apparent that it's an issue with my vehicle), does anyone have any suggestions?
  2. Sep 21, 2018 at 10:56 AM
    jester243
    Dan
    Spokane, WA
    I cant remember the instructions off the top of my head but I think they have to be in a folder with a specific name for it to see them
  3. Sep 21, 2018 at 10:58 AM
    jester243
    Dan
    Spokane, WA
    here, it says it is case sensitive, hope it works:
    103406d1385266026-4runner-startup-displa_d03074b76fd8e3a888a1b00030e2c2d37dd1a63c.jpg
  4. Sep 21, 2018 at 12:28 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    I cant recall, exactly, but you have to put something like .startup or something like that on the file name for the source to see it.. search on YouTube for it. That's how I did mine, some dude had a vid to tell you what to put on the file names
    Edit (i wasnt even close lol )
    https://www.youtube.com/watch?v=7jqRFnGqwEM
  5. Sep 21, 2018 at 1:22 PM
    Richmond Dan
    Richmond, VA
    I did all that. The problem is not an ability to recognize the files, it can’t even access the thumb drive. The RAV4 sees the thumb drive just fine.
  6. Sep 22, 2018 at 7:57 AM
    Richmond Dan
    Richmond, VA
    Just hooked my iPhone up using the USB port and it worked fine (charged phone and played music). That means that the USB port is fine, just some mismatch with the thumb drive. I'll try a different thumb drive using the same format (FAT32) and file structure to try to isolate the problem and report back.
    Kyblack76 and jester243 like this.
  7. Sep 22, 2018 at 11:49 AM
    Richmond Dan
    Richmond, VA
    I tried a different thumb drive and it worked as advertised (I copied the folder and files to the new drive). The first drive must not have able to seat properly in the 4Runner, because it worked fine in the RAV4. Thanks for all the suggestions...
    jester243 likes this.
  8. Apr 19, 2023 at 11:34 AM
    Bencaught
    Bencaught New Member
    I had the same issue tried 3 or 4 different usb drives. Pulled a brand new 128GB sandisk and it worked. But what I found is that the partition was MBR and the rest were GPT. Hope this helps others.
  9. Apr 20, 2023 at 10:41 AM
    beedee
    beedee Member
    I'm having the same issue, tried two different USB Thumb Drives...granted they are pretty old.
