UCA replacement?
Discussion in '5th Gen 4Runners (2010-2024)' started by Bigbear45acp, Apr 3, 2026.
  1. Apr 3, 2026 at 4:32 AM
    Bigbear45acp
    Bigbear45acp [OP] New Member
    Ben
    2023 T4R ORP
    Question….if you replace front and rear shocks Bilstein 6112- front and 5100-rear along with new rear springs, do you have to replace the front upper control arms? I achieved a 2.5” overall lift. I’ve been told conflicting information.
    Thanks.
  2. Apr 3, 2026 at 4:42 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Bilstein 6112/Icon 2" rear TSO bumper 285 MT Baja Boss Northstar x2 Voltage pro booster
    I only went about 2" with my 6112's and put in Old Man Emu UCA's. Probably could get by without them, but they were 100 bucks off at the time. Happy with my decision to get them. No noise and greaseable ball joint.
  3. Apr 3, 2026 at 4:47 AM
    Bigbear45acp
    Ben
    2023 T4R ORP
    Thanks for the response. Did you have “noise” before you replaced the factory UCA’s? I’m not an off roader, just wanted some lift.
    What’s the overall benefit to do this? Is it more for serious off-roading? I might go off-road 10%
    Appreciate your help.
  4. Apr 3, 2026 at 6:01 AM
    Gravel
    Gravel New Member
    SR5 4x4
    What I’ve heard is that due to the angle of the UCA mount, you lose caster (self-centering/stability) angle as ride height increases. Everything I’ve read says that stock UCAs are good at about 2” of lift and less, above 2” you need the additional caster built into aftermarket UCAs to get good alignment numbers.
    How’s your ride and handling?
    Toy4X4 likes this.
  5. Apr 3, 2026 at 6:33 AM
    Bigbear45acp
    Ben
    2023 T4R ORP
    Hi and thanks for the response. Right now, the ride and handling are really good. I’m just wondering that I may create suspension component damage if I don’t change out the stock UCA’s.
    What do you think?
  6. Apr 3, 2026 at 6:38 AM
    L
    20 Venture/17 Taco
    One of the "benefits" is that upgrading to new UCA's allows you to adjust caster and other things as you try to fit 33s or bigger tires. You can still run the OEM uca's and be fine no issue, but if you start getting out there, and going to bigger/heavier tires, then the UCA's come into play. Particularly, when you try to get alignments and all that stuff. I would get some basic ones and just be done. :spending:
  7. Apr 3, 2026 at 6:42 AM
    Bigbear45acp
    Ben
    2023 T4R ORP
    OK, thanks for the advice, I appreciate it very much. Holy cow, I see what you all mean with these mods/upgrades….it never stops!
    Toy4X4 and NB4x4 like this.
  8. Apr 3, 2026 at 7:10 AM
    Gravel
    Gravel New Member
    SR5 4x4
    4Runners are the most modifiable thing I’ve ever owned!
    I’d say that if you’re happy with how it rides and drives, then nothing else is needed. If you want to add UCAs, it should be an improvement in handling when the alignment is closer to perfect, but it probably won’t be a huge difference, I think?
    I’m planning a similar project on mine, (6112/5100, UCAs and rear springs) but it’ll be all at once so I won’t know the difference step by step. If you decide to add UCAs it’ll be interesting to hear what you think.
    I just got a set of tubular Dobinson UCAs for a great price on Amazon, they’re out right now but if you’re looking I’d watch there. Otherwise I was planning on a set of Freedom Off Road UCAs, they’re visually identical to the Dobs, but less than half the normal retail price.
    TrailSpecial22 and Toy4X4 like this.
  9. Apr 3, 2026 at 8:00 AM
    L
    20 Venture/17 Taco
  10. Apr 3, 2026 at 8:02 AM
    I had SPC UCAs on my TRD ORP, the suspension was ELKA 2.5 dual adjusters. I don't know if its the UCA or shocks, I can hear squeak kinda sound when I drive over a bump. Since I don't do my own oil change the toyota dealer does not re-grease the UCA. it was a pain for me to re-grease every oil change.
    I'm so glad my Limited & TRD Pro have Toyota OEM UCA that is quiet and no maintenance needed.
    NB4x4 likes this.
  11. Apr 3, 2026 at 9:49 AM
    Gravel
    Gravel New Member
    SR5 4x4
    Kmeeg, that’s why I bought UCAs that use OEM type ball joints and OEM type frame bushings. Poly bushings and uniballs work great with regular maintenance, but stock style works great with virtually no maintenance..
    NB4x4 and kmeeg like this.
  12. Apr 3, 2026 at 12:14 PM
    Guppy1301
    Silver 2019 TRD ORP
    I came from an FJ with Icons and TC UCA's with uni-balls. They can get noisy in a hurry if you don't keep them clean. Also, poly bushings in the UCA's can get squeaky. Lot of maintenance involved in my opinion. That's why I went with the OME UCA's.
  13. Apr 3, 2026 at 11:03 PM
    DocSR5
    DocSR5 New Member
    Cave Creek, AZ
    2023 SR5
    I’ve got this exact setup on my 23’ SR5. Love the setup but will need to adjust the cerclip settings to 5/7 from 4/6 as I only got 1.5” lift up front (instead of 1.9”) on account of the C4 low profile bumper.
    I like the Dobinson tubular UCAs as the bearings r rubber (quiet) and similar to OEM. I do wish there was a zerk fitting on UCAs to allow for greasing onoccasion. Overall very pleased with the 6112/5100 Dobinson setup.
    Gravel[QUOTED] likes this.
  14. Apr 4, 2026 at 8:03 AM
    youre on the edge at 2.5”, but imo no you dont need to replace. Only replace if you cant get alignment to spec. My oem uca aligns fine at 2” with your set up and I have 285/70/17 on stock rims
    NB4x4 likes this.
  15. Apr 4, 2026 at 1:04 PM
    Bigbear45acp
    Ben
    2023 T4R ORP
    Thanks for your input, I appreciate it!
  16. Apr 4, 2026 at 3:30 PM
    At 2.5 inches, you might not be able to get caster numbers in spec with the stock UCA, at least not with mine, but only by around 0.1 degrees. What will that mean? Your steering might feel a little lighter and it may not return to center quite as sharply…not that it ever returned to center sharply on my bone stock 4runner.
    This is something I got used to, pretty quickly. If you can’t get used to it, that would be a good reason to get aftermarket UCAs. But, like a few here have already mentioned, make sure you get ones that come with factory style ball joints and rubber (not poly) bushings. Unless you don’t mind more maintanance, more frequently.
    I kept my factory UCAs on the assumption that they are better than good aftermarket UCAs, in terms of ease of maintanance and durability for daily-driver use.
    I’ve got about 75k miles on my stock UCAs since I lifted my 4runner about 2.5 in. So far, so good. I even got an extra set of nearly new factory takeoffs ready to go for when I wear out my ball joint (which I assume will be the thing that wears out).
  17. Apr 4, 2026 at 3:53 PM
    my stock uca are still on my 2011 with a 2” lift and 285/70/17. Just hit 176k.
    kmeeg likes this.
  18. Apr 4, 2026 at 7:58 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    how many miles on UCA’s?
    thanks
  19. Apr 4, 2026 at 8:30 PM
    L
    20 Venture/17 Taco
    SPC for the win!
    :crapstorm::crapstorm::crapstorm:
  20. Apr 5, 2026 at 4:08 AM
    Guppy1301
    Silver 2019 TRD ORP
    Right around 70-75K.
    djwantke[QUOTED] likes this.
