Turnsignal and puddle light mirror swap
Discussion in 'Lighting' started by audiopro69, Oct 2, 2022.
  1. Oct 2, 2022 at 4:58 PM
    audiopro69
    audiopro69 [OP] New Member
    Taz
    Valley Forge PA
    22 TRD PRO
    None yet
    Hi all just got my 22 TRD PRO
    fist mod I want to do other than a slight lift to fit 285 tires is to swap the side mirrors out for the ones on the OFP with the turn signals and puddle lights
    I understand that there is a harness from a guy called Tanner aka Old Red
    But it seems he is MIA
    I did send him a DM via insta and seems
    He is a on this forum from time to time
    So if anyone has contact with him can they point him my way
    Any other options??? Other than OldRed harness ?????
  2. Oct 2, 2022 at 6:13 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    @Old Red is around quite often. He will reply, you'll see.
    Gryphon771 and Old Red like this.
  3. Oct 2, 2022 at 6:33 PM
    Old Red
    Old Red New Member
    Washington
    It's a long list...
    I'm around quite a bit, I just don't always log in when I read stuff on here. Saw your DM and replied.
    Usually I do stuff in batches when I get the time to produce these, so right now I don't have a set "production schedule". Usually that's a free weekend or two when I'm not getting pulled 10 different directions. I will post up what I replied to you regarding the 22MY TRD PRO (Edit: Looks like Toyota finally figured it out and put Premium Mirrors on 23MY TRD Pro from the factory!)
    The harness setup that I have designed currently does not work with the 22MY Pros because of the addition of the Multi-terrain monitor camera system that is standard Pro equipment. It has to do with a connector/terminal difference and the fact that replacing the mirrors with the Premium ones w/MTM system will run you about $600-700 a mirror (OEM are the only ones that will work due to the MTM system).
    So it's not cost effective to replace a whole mirror for the 22 Pro. I'm currently back channeling with the OEM to see if it is possible to get individual components to change out on the existing pro mirrors to retain the stock cameras and add the components required without swapping the entire mirror assembly. I will post up info regarding the outcome of this when I have a definitive answer.
  4. Oct 2, 2022 at 6:34 PM
    Old Red
    Old Red New Member
    Washington
    It's a long list...
    Yep, just have to use the @username. Wish I had more time to participate these days.
    audiopro69[OP] and 2Toys[QUOTED] like this.
  5. Oct 3, 2022 at 5:57 AM
    audiopro69
    Taz
    Valley Forge PA
    22 TRD PRO
    None yet
    @Old Red thanks for the reply here and to my DM look forward to your findings on this for us with 22-23 TRD PRO’s
    as many have stated before the fact that Toyota leaves these features out of the flagship model makes no sense to me
    and slightly bummed that I just found out apparently they finally added heated steering to the 23 lineup….. bet steering wheel swaps will be the next big mod
  6. Oct 3, 2022 at 7:54 AM
    danno1948
    danno1948 New Member
    Dan
    1999 grey 4wh dr
    pretty much stock except wheels /tires
    do you make this harness for a 2021 TRD Off road, i would be interested also. They did away with them on my year also Thanks
  7. Oct 5, 2022 at 4:37 PM
    Old Red
    Old Red New Member
    Washington
    It's a long list...
    Yep I do. It will work for all base models from 2014-22 Except the 2022-23MY TRD Pro. I have no idea about 2023MY yet.
  8. Dec 31, 2022 at 9:29 AM
    I'm just curious - for those who have done this mirror swap, where exactly does the Old Red harness plug into on the inside? I searched to find a thread on the development of this wire harness, and am coming up empty.
  9. Jan 29, 2023 at 1:51 PM
    matoolie
    Michael
    2021 Lunar Pro
    Connects at OEM connectors in both kick panels.
  10. Jan 20, 2025 at 8:00 PM
    Squirre11
    Squirre11 New Member
    William
    2020 4Runner TRD Off Road w/keyed ignition
    FitCamX, Start-X remote start for keyed ignition
    Greetings Ole Red, I am interested in the wiring harness adapter to convert 2020 4Runner with heated mirrors to the heated, turn signal indicators, and puddle lights. Please contact me with details. Thank you!
