Trusted place for alignment
Discussion in 'Wheels & Tires' started by Lucky9924, Mar 18, 2025.
  1. Mar 18, 2025 at 8:37 PM
    Lucky9924
    Lucky9924 [OP] New Member
    1999 and 2024 TRD ORP
    I need an alignment after going from highway tires to AT tires. I got them at Costco and they don’t do alignments.
    I’ve read that the trusted place is Discount tires. When I google DT near me, Americas Tires pop up and another one called “Discount Tires and Service Centers”.
    So which one is the real DT?
  2. Mar 18, 2025 at 8:47 PM
    bobby4runner
    bobby4runner New Member
    Los Angeles
    2022 TRD Pro MBM
    Where in Cal are you? If you're in LA area, I can vouch for RPM Garage for AT balancing and alignments.
    And Discount Tires is known as Americas Tires in California.
  3. Mar 18, 2025 at 8:57 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Unless you've changed something with the suspension, you don't need an alignment.
    (Caveat for the 'but what if' crowd, yes, there are other situations where an alignment is recommended, but a simple tire change ain't it)
  4. Mar 18, 2025 at 8:58 PM
    Lucky9924
    Thanks. Too far from LA, I’m more inland. I saw America’s Tires but the other “Discount tires and service center” place confused me.
  5. Mar 18, 2025 at 8:59 PM
    Lucky9924
    No changes with the suspension. It was perfectly fine before the AT tires. Costco said the tread pattern is different so an alignment may be needed.
  6. Mar 18, 2025 at 9:12 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Maybe the tech noted odd tire wear on your old tires, and thought an alignment could help?
    But again just changing tires 100% is not a reason to get an alignment.
  7. Mar 18, 2025 at 9:25 PM
    Lucky9924
    @PVT Pablo
    Old tires (and my barely driven 4Runner) only had 1800 miles when I got the new A/T tires about 2 weeks ago. So unlikely that it had any odd tire wear.
    I’d be happy to bring it to another Costco for a 2nd opinion as that won’t cost me the alignment charge.
  8. Mar 18, 2025 at 9:40 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I'd recommend not asking another Costco as you stated, they aren't alignment techs.
    If you feel inclined to get an alignment based on their advice, go for it! It won't harm anything verifying alignment. Just cost ya a little time and money.
    If it were me though, I'd skip it.
  9. Mar 19, 2025 at 7:15 AM
    Gman2530
    Gman2530 New Member
    2018 SR5 4wd 4Runner
    Discount tire/American tire in San Diego, does not do alignments
  10. Mar 19, 2025 at 7:35 AM
    Most any shop with the proper equipment can do an alignment. As long as you get a printout of the numbers I wouldn’t worry.
    You can keep an eye on how your tires wear if you suspect you may need an alignment.
    Lucky9924[OP] and Tama1968 like this.
  11. Mar 19, 2025 at 9:00 AM
    hope your camber/caster bolt isnt seized like mine. Mine is a 2022 and its already seized. If its bad, they have to cut out the lower control arm and replace the LCA. Just want to give you a heads up
  12. Mar 19, 2025 at 1:09 PM
    blksubykid
    blksubykid New Member
    Sibi Built
    RPM Garage
    Truck Shop SD
