Trunk Organizer
Discussion in '5th Gen 4Runners (2010-2024)' started by celaw309, Apr 22, 2020.
  1. Apr 22, 2020 at 11:35 AM
    celaw309
    celaw309 [OP] New Member
    Chris
    NY
    2020 MGM TRD ORP
    I've done some searching online for an organizer for all my stuff (4way, tow ropes, tools, etc.) and haven't been super impressed with the cheap-looking fabric/thin plastic offerings. What are you using? Any suggestions?
    -Chris
  2. Apr 22, 2020 at 3:09 PM
    Backwoods
    Backwoods New Member
    2019 silver SR5 4x4
    This works great for me. With the wheels it's easy to remove when not needed. Holds tools, straps, battery jump starter, air compressor, axe, and lots of other odds and ends.
    celaw309[OP] likes this.
  3. Apr 22, 2020 at 3:26 PM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    I use a tool bag. It’s soft, and conforms to the cargo space. Easy to move around and holds quite a bit, including a 24” breaker bar so that I can get wheel nuts off.
    mrmike7189 and DrewMan like this.
  4. Apr 22, 2020 at 4:48 PM
    2A4R
    2A4R New Member
    Northern VA
    19 4R TRD PRO
    I use a pelican case for all my recovery gear ect. I live it, it is extremely durable, has wheels and an extendable handle. It is definitely on the expensive side, however I intend on putting it on the roof once my Gobi rack arrives and the pelican cases are excellent at keeping the weather out. It also comes with foam if you want to make specialized compartments within the case for delicate items
    There are also a huge assortment of sizes.
  5. Apr 22, 2020 at 7:36 PM
    celaw309
    Chris
    NY
    2020 MGM TRD ORP
    Nice! I was thinking Pelican after I posted this. What size do you have?
    2A4R[QUOTED] likes this.
  6. Apr 22, 2020 at 7:37 PM
    celaw309
    Chris
    NY
    2020 MGM TRD ORP
    That's kind of what I have now but would like something a little larger and more durable.
    Oldtoyotaguy[QUOTED] likes this.
  7. Apr 22, 2020 at 7:53 PM
    2A4R
    2A4R New Member
    Northern VA
    19 4R TRD PRO
    This was my inspiration (also same size - 1650).. @gun.rnr on Instagram
  8. Apr 22, 2020 at 8:05 PM
    celaw309
    Chris
    NY
    2020 MGM TRD ORP
    Awesome, thank you!
  9. Apr 23, 2020 at 6:59 AM
    Oldtoyotaguy
    I’ve added a bit more stuff, and I’m going to get another matching bag, and probably zip tie a marker on it. That way I can differentiate my kit for when I’m on or off road. There’s no sense carrying a lot of off road gear around when I’m mall crawling.
    Wvmoonshiner, 7385 and SlvrSlug like this.
  10. Apr 27, 2020 at 12:46 AM
    Checook
    Checook New Member
    Che
    15 4runner SR5 4x4 Silver
    I installed a permanently mounted gun safe in my rear but wanted storage on top that is non permanent but doesn't move around. I took an industrial box and mounted strong magnetic feet coated in rubber on top. Good for a few tools, lunch box and my duty belt.
    celaw309[OP] and 2A4R like this.
  11. Apr 27, 2020 at 3:50 AM
    2A4R
    2A4R New Member
    Northern VA
    19 4R TRD PRO
    That's a good idea with the magnets
  12. Apr 27, 2020 at 4:54 AM
    Drababan
    Drababan New Member
    2020 4Runner TRD Pro (Pickle Rick)
    I'll take a picture of mine later but it's a Yeti Loadout GoBox. The rubber pads on the bottom are great so it doesn't slide around on the cargo tray (carpet).
  13. Apr 27, 2020 at 10:39 AM
    4x Old Guy
    4x Old Guy New Member
    Riverside, CA
    Big-O Bigfoot A/T tires
    I haven’t pulled the trigger on any inside storage yet, but my plan is to take a modular approach with multiple smaller boxes. Which box(es) go in the truck depends on what the trip will be.
    Basic “daily driver” stuff (jumper cables, tie-downs for the inside anchor points, small first-aid kit, multi-tool, light duty tow rope, flashlight, road flares, and similar) will “permanently” go in the factory nooks and crannies and under the slide out rear cargo deck.
    Additional stuff for long (paved) road trips will go in a small box (weather dependent items like chains, extra water, survival blankets, snacks, oil, tie-wraps, duct tape, etc).
    Off-road gear (recovery gear, compressor, shovel, hatchet, etc) would go in its own box.
    The anticipated trip type determines which box(es) go in the truck.
  14. May 2, 2020 at 6:03 PM
    celaw309
    Chris
    NY
    2020 MGM TRD ORP
    Pulled the trigger on the Pelican! Very happy with it so far.
    Aniki, 4RUNNYFUN and 2A4R like this.
  15. May 2, 2020 at 6:07 PM
    Pirateghost
    Pirateghost New Member
    2020 Limited
