Truck Height with 2" lift and 33's??
Discussion in '5th Gen 4Runners (2010-2024)' started by AZ-4runner2012, Sep 30, 2018.
  1. Sep 30, 2018 at 11:59 AM
    AZ-4runner2012
    AZ-4runner2012 [OP] New Member
    Michael
    2012 Limited 4Runner - AZ
    Stock as of now, Shocks and Struts are needing to get replaced, so getting a blistein 5100 installed in 2 weeks, thinking of getting the 2" lift and thinking about 33" tires and new rims.
    I've been reading a lot of posts and decided to post my question...
    I have a stock 2012 4x4 4runner limited that is getting a blistein 5100 installed in 2 weeks. I park in underground parking with a height limit of 6 ft, 6 in.
    What would be the height of my 4runner with a 2" lift and a set of open country A/T Toyo 33" tires (LT285/70 R17)?
    Thanks for any advice or answers!
  2. Sep 30, 2018 at 1:13 PM
    4X4Runner
    The left coast
    With my 4Runner sporting a 3” OME suspension lift, 285/70/R17’s and an ARB touring rack I sit at 6’8” to the top of the rack.
    If you’re not running a rack and just have the stick rails you should be perfectly fine. I would venture to say you’ll probably be around 6’2” max
    ruiz4251 likes this.
  3. Sep 30, 2018 at 2:08 PM
    I am running 2 1/2" in the front with 2" longer springs in the rear with 285/70/17 MTs, and to the top of the oem rail cap i am at 6'4"
  4. Sep 30, 2018 at 5:48 PM
    AZ-4runner2012
    Michael
    thanks to both of you for the insight and the rack options in case I decide to add that in the future.
