TRD skid plate more oil change friendly?
Discussion in '5th Gen 4Runners (2010-2024)' started by Griz74, Jan 1, 2024.
  1. Jan 1, 2024 at 4:54 PM
    Griz74
    Griz74 [OP] New Member
    New owner of 2023. Just wondering if the TRD skid plate is more friendly to use for oil changes, than the stock plate?
  2. Jan 1, 2024 at 4:57 PM
    Nope, the TRD plate has to be completely unbolted and removed.
    You're best bet would be an aftermarket skid plate that has the access door built into it.
    ljerr2 and kmeeg like this.
  3. Jan 1, 2024 at 5:01 PM
    True^,
    Pulling the front skid for the oil filter change can be annoying, but it does give you the opportunity to take a good look at the bottom of the engine and surrounding underside if that’s your thing.
  4. Jan 1, 2024 at 5:13 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I had a TRD skid plate for 6ish years. As posted above, all four bolts must be removed to change the oil filter. To just drain, the skid plate can stay on.
    Removing the 4 bolts isn't hard, but recommend anti-sieze and starting the bolts by hand to stop cross threading. I'd also recommend getting internal tooth washers to keep the front spacers in place as they're kinda annoying to reinstall.
    Ironguy and Trail Runnah like this.
  5. Jan 1, 2024 at 5:23 PM
    jev425
    jev425 New Member
    Seattle
    2022 Nautical Blue TRD Off-road
    I was on the fence about buying the oem skid for my 4Runner and ended up buying the car trim aftermarket one(looks a lot like oem). It has an access door for oil changes and I bought the one that comes in black.
    ljerr2 likes this.
  6. Jan 1, 2024 at 5:39 PM
  7. Jan 2, 2024 at 3:43 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    I had the TRD skid on for a year, switched to the stud mount (which was a great improvement) that made it slightly easier to change the oil, but switched to an RCI aluminum skid this summer. So much easier to change the oil, looks great and offers a little more protection. It was about $150 more than the CarTrim version and only about $50 more than the TRD version.
    ualfltdispatch and Trail Runnah like this.
  8. Jan 2, 2024 at 4:49 AM
    ljerr2
    ljerr2 New Member
    IOWA
    2023 T4R Pro
    I did this as well. I liked that it "looked" like an OEM TRD but had the subtle but huge advantage of an access door for the oil filter. QC was not the greatest on the one I received, but I was able to modify it slightly to correct a few deficiencies that makes it really great (at least in the "looks" department - probably not the best option for true off-road protection but I'm not a rock-crawler type.)
    I had to slightly modify the letters' retaining tabs so they'd fit squarely in the skid plate, added heli-coil thread inserts for the acess panel screws for durability, and changed all hardware to OEM instead of the black oxide included with the cartrim plate. For the access door, I got some shallow head SS screws.
  9. Jan 2, 2024 at 8:03 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    ^^^THIS IS IMPORTANT^^^ And, c'mon, it's not really that hard. 5 12mm bolts and it's off.
  10. Jan 2, 2024 at 8:54 AM
    You are talking abount an OEM / Non TRD plate.
    TRD plate only has 4 bolts.
    My mod has 4 Studs and nuts and is super easy . No fighting getting the bolts to line up!
    ljerr2 likes this.
  11. Jan 2, 2024 at 9:04 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    You are correct. I still stand by my statement that it's not that difficult. Been doing it for 13 years now, every 5K, 180K on it now. 36 times just for oil changes. FYI: I did look at the mod.
    Saker[QUOTED] likes this.
  12. Jan 2, 2024 at 9:17 AM
    CTH offers a china version of the TRD brah with an access panel. I think it can deflect wind.
    Saker likes this.
