TRD Pro wheel torque spec?
Discussion in '5th Gen 4Runners (2010-2024)' started by wolfman, Aug 21, 2022.
  1. Aug 21, 2022 at 5:09 PM
    wolfman
    wolfman [OP] New Member
    I can't finds a definitive answer! Is it 85, 76, 83? Google tells me all different answers! Anyone know for certain? Sorry. Love yoo.
  2. Aug 21, 2022 at 5:31 PM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    It is 76 ft lbs
  3. Aug 21, 2022 at 5:33 PM
    Loco x Toyota
    Loco x Toyota New Member
    Cedar Park, TX
    TRD Pro Solar Octane
    76. But do tightened to 85 when you start using aftermarket wheels and tuner lug nuts, you need more torque to compensate conical lug nut torque friction loss
  4. Aug 21, 2022 at 5:47 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    10-12 uhga duhgs...:cool:
  5. Aug 21, 2022 at 5:50 PM
    Tmiesowicz
    Tmiesowicz New Member
    The better half of New York
  6. Aug 21, 2022 at 6:20 PM
    I asked the same question and was told by my dealership that they consider the pro rims as aftermarket and torque to the higher spec of 85 ft lbs.
  7. Aug 22, 2022 at 4:51 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Why does a different rim matter ?
  8. Aug 22, 2022 at 6:56 AM
    No clue.
  9. Aug 22, 2022 at 6:36 PM
    wolfman
    Thank you!
    Stock wheels, so 76 I guess. Thanks!
    Awesome. Thank you
    But they're aluminum. Ugh. Dealers always giving out different info. Yikes.
  10. Aug 25, 2022 at 2:35 PM
    Loco x Toyota
    Cedar Park, TX
    The TRD Pro wheels should still be classified as Factory/OEM wheels because they use this type of lug nuts
    torque spec set by the manufacturer has nothing to do with the wheel's property itself, only 2 factors affect the lug nut torque:
    1. wheel studs dimension
    2. lug nut style
    Toyota set 76 lbft for 4Runner's application using above lug nuts.
    Almost all other aftermarket wheels use tapered lug nuts like these
    these 60-degree tapered lug nuts, apply less clamping force when compared to OEM style lug nuts, even torqued to the same spec.
    Thus 85 lbft instead of owner's manual's 76 to get closer to the same clamping force between the wheel and the rotor.
    If the dealership wants to torque those TRD Pro wheels lug nuts to 85, sure, not going to harm anything in my opinion, it's when they torque it higher than 100 lbft and you might see studs elongation that weakens the studs.
    semprenissart, Cowboy59 and wdsteven like this.
  11. Aug 25, 2022 at 4:25 PM
    wdsteven
    wdsteven New Member
    Would rather NOT have them set at Higher Torque than the Toyota Specs because I have a Pair of TRD Pro Rims gave to me that were Warped from either or both Over Torque / Incorrect pattern or Slammed down with Impact Wrench. I took em because I thought I could get them corrected and use as spares but now they are going to become bar stool bases since they are that bad.
    Loco x Toyota[QUOTED] likes this.
  12. Aug 25, 2022 at 4:51 PM
    Loco x Toyota
    Cedar Park, TX
    Don't let any dealership or tire shop mount the wheels, they all use air tools, which definitely shoot over 100 lbft.
    I invested a 3 ton jack just to do my own tire rotation, worth it if you like to have control over everything.
    Unfortunately, I still have to go to Discount Tire for mounting and balancing tires, they do a good job and I still slip a $20 bill to the technician just to make sure extra care is taken not to scratch the wheels. I'll then load the balanced tires/wheels to my truck and mount to the 4Runner at home.
    Cowboy59 and wdsteven[QUOTED] like this.
  13. Aug 25, 2022 at 5:36 PM
    wdsteven
    wdsteven New Member
    Well I am Certainly not going to Let Any dealership do any work on my Toyotas because I Do that work myself with another person (Only on Toyota) and only Project type work on Weekends early Toyota's are a Fav like the ones a Dealership will scoff at
  14. Aug 25, 2022 at 9:41 PM
    I’m pretty sure my dealership torques my Pro rims to 85 Ft lbs.
  15. Aug 17, 2024 at 1:00 PM
    Smokey 24’ TRD PRO
    Smokey 24’ TRD PRO New Member
    NY
    ‘24 4R TRD PRO
    So for the TRD PRO rims 76?
  16. Aug 17, 2024 at 1:29 PM
    Depend on the year. :p https://www.4runners.com/threads/lugnut-torque-spec.34870/
    This started in 2015. 2014 and prior manuals didn't have the lower torque for aluminum wheels.
    I checked the GX manuals and it's the same. Lugnut torque went from 83 ft-lb in 2014 to 76 ft-lb in 2015.
    Of course professional technicians will just pick the yellow torque stick and give it 3 ugga-duggas.
  17. Aug 17, 2024 at 1:46 PM
    The TRD Pro wheels are known to have a short center bore recess that fits only the 4Runner. I suspect yours were previously attempted to be installed on a different Toyota model (like a Tacoma). The method of tightening lugnuts would have been immaterial in this case - manual tightening with a torque wrench would have also warped the wheel.
    Overtorquing doesn't harm the wheel. Worst case it breaks a stud. On other cars with thin hubs or aluminum hubs, the hub can be warped.
  18. Aug 17, 2024 at 4:29 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    I just looked at the pamphlet that comes in the box with each Pro wheel and it says 83 ft lbs .
    5thToy likes this.
  19. Aug 17, 2024 at 6:38 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Do you have a picture? That’s strange because the owner’s manual states 76 for aluminum wheels
  20. Aug 18, 2024 at 6:43 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Each wheel comes with this pamphlet in the box .IMG_0580.jpg IMG_0581.jpg IMG_0580.jpg IMG_0581.jpg
  21. Aug 18, 2024 at 8:36 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    this is what I was going to post. Vehicle owner manual says aluminum at 76 while the pamphlet that comes with the Pro wheel says 83.
  22. Aug 18, 2024 at 8:38 AM
    semprenissart
    semprenissart Mèfi
    Strange. I figured it would say 83 thinking you’d have to use the OE non pro lug nut which are conical. But the instructions clearly state to use the flat pro lug nut and NOT the conical. Which from my understanding the lower 76 torque number was due to the flat nuts.
    Sorry I can’t be more helpful
  23. Aug 18, 2024 at 9:41 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    7 ft lbs difference isn’t much so either one probably works just fine . Heck split the difference and go 80.
    Slopemaster, Treggit and TRDGrey2021 like this.
  24. Aug 18, 2024 at 12:58 PM
    Trees91
    Trees91 .
    Forrest
    South Dakota
    2023 MGM SR5p
    That's what I do. Set it at 80 and call it good
  25. Aug 18, 2024 at 1:17 PM
    BrianB24
    BrianB24 New Member
    Brian
    Louisiana
    24 4Runner TRD Pro
    our 24 calls out 76 lbs....
  26. Aug 20, 2024 at 5:55 AM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    THe lugnuts have a different seat contact area. Aftermarket are more conical in their seal to the rim, where as stock is slightly flatter. Effects torque application due to different contact patch.
  27. Aug 20, 2024 at 3:36 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Agreed. Splitting hairs. My owners manual also says 76 ft lbs for factory off road rims and 83 ft lbs for the Trd non pro rims. What's more important though is that you recheck the wheel nut torque after 100 miles or so. Any tire shop shop will tell you this. Especially with aluminium rims. They can loosen after they fully seat.
    Nick B[QUOTED] likes this.
  28. Aug 20, 2024 at 3:43 PM
    Next year will be interesting, when Toyota switches to beefier 14mm studs.
  29. Aug 20, 2024 at 3:43 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    It means 2010 forward on the 4R and 2007 forward on the FJ .
    Or in other words 2010 and up . That’s why it shows 2010- .
    3JOH22A[QUOTED] likes this.
  30. Aug 20, 2024 at 4:02 PM
    Redwood
    Redwood New Member
    Yes. I have the factory bronze non pro TRD wheels for '22 and the pamphlet that came with them shows the same. 2010 and up.
