TRD Pro vs TRD ORP Wheels
Discussion in '5th Gen 4Runners (2010-2024)' started by legend1011, Dec 1, 2025 at 1:59 PM.
Wheel Choice on White 5th Gen?
  1. TRD ORP
    17 vote(s)
    36.2%
  2. TRD Pro (Matte Gray)
    6 vote(s)
    12.8%
  3. TRD Pro (Matte Black)
    19 vote(s)
    40.4%
  4. Other?
    3 vote(s)
    6.4%
  5. TRD Pro (Bronze)
    2 vote(s)
    4.3%
  1. Dec 1, 2025 at 1:59 PM
    legend1011
    legend1011 [OP] New Member
    Looking for Opinions because I am on the fence... Thank you!
    I'm still on the original tires that came with our 2024 ORP. I am going to try and get through 1 more year of burning up the tread on them before getting new All Terrain tires. Purchasing new tires has me thinking about possibly upgrading the wheels as well. I know the TRD Pro wheels appear to be the go-to upgrade (Black seems most popular).
    • Does anyone prefer the TRD ORP Wheels over the TRD Pro Wheels? I have read that the TRD Pro wheels can be hard to clean. Outside of saving money on one less upgrade and ease of cleaning, any other advantages of keeping the TRD ORP Wheels over the TRD Pro?
    • Does anyone have the TRD Pro Matte Gray/Gloss Gun Metal over the black TRD Pro Wheels? If so, what was your reasoning behind going with the Gray over Black? Most of what I see in my area is black TRD Pro wheels, so I am leaning more toward the Matte Gray to be a little different. I also am considering changing my overlays to Matte Gray/Gun Metal to match the wheels for a unique look (wife isn't a fan of the storm trooper look, but I'm still undecided).
    I can get by this winter, but I'm trying to make a decision before next winter. I see that there were Black Friday sales on the TRD Pro Wheels with the dealer 25% Black Friday discount, but I'm not ready to pull the trigger just yet. Still deciding on what I want going forward.
    For what it's worth, I checked FaceBook Marketplace and most of the listings I see are TRD ORP Wheels which I assume are tied to people upgrading to the TRD Pro or another aftermarket wheel. It seems like people are eager to upgrade the TRP ORP Wheels - I'm not sure if there is something people don't like about the TRP ORP Wheel or if the TRD Pro is considered a more premium wheel because it's association to the Pro Trim.
    I appreciate any info/opinions on this.
    EDIT: Found this pic in another thread for reference:
    Referenced Member: wmdtech
    https://www.4runners.com/threads/trd-pro-wheels-in-gray-250.10262/[​IMG]
    Here is mine:
    Found on Carmax:
  2. Dec 1, 2025 at 3:01 PM
    Run them both. Get a set of Pro wheels and put winter tires on them and keep the OR wheels and tires for summer
    HeadedToTexas, vthoky and Saker like this.
  3. Dec 1, 2025 at 3:24 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Gun Metal or Bronze on white runner
    Obviously, black is always a safe choice
  4. Dec 1, 2025 at 3:25 PM
    Pentangler
    Pentangler Happy Member
    ORP wheels are wider with more offset than the oem Pro wheels.
    2Toys, MeefZah, Stoney Ranger and 2 others like this.
  5. Dec 1, 2025 at 3:52 PM
    Shredder
    Shredder New Member
    tip of the mitt, Michigan
    23 OR
    Tires, shocks
    You really don’t wanna know my opinions. :lalala::lalala:
  6. Dec 1, 2025 at 4:03 PM
    Imdav2u
    23 TRD PRO
    I like mine, I use Turtle Wax Ceramic Coating and tires shine.
    JET4 and 2ndGen22re like this.
  7. Dec 1, 2025 at 4:18 PM
    2019 TRDP w/Kangs brah!
    The Pro Bro wheels are just for looks. As I understand it they are narrower than the TRD wheels.
  8. Dec 1, 2025 at 4:22 PM
    legend1011
    To be honest, I didn't even consider the Bronze. I'm looking up pictures of them now. Probably overthinking it, but don't want to have any regrets if I switch away from the TRD ORP. Thank you!
  9. Dec 1, 2025 at 4:39 PM
    Me personally love TRD Offroad wheels been wider, having extra valve stem protection. To my eyes it looks very clean.
    2Toys, MeefZah, Stoney Ranger and 5 others like this.
  10. Dec 1, 2025 at 7:10 PM
    rwturbo
    rwturbo New Member
    ronnie
    2006 4runner
    Following. I’m also torn between the two.
    glwood54 likes this.
  11. Dec 1, 2025 at 7:44 PM
    hossler1788
    hossler1788 DADWAGON
    Joshua
    Central Pa
    2020 4runner
    Why not just get some decent aftermarket wheels?
    So many different brands offering quality wheels. Just when buying aftermarket, make sure to pay attention to wheel weight, load rating, and offset/backspacing.
    ChessGuy likes this.
  12. Dec 1, 2025 at 7:45 PM
    Levi9
    Levi9 New Member
    Portland, Oregon
    24 TRD Pro, Super White
    I wish mine were grey.
    If you going to buy a new set of wheels, I don't think TRD Pro wheels are the best choice.
  13. Dec 1, 2025 at 8:09 PM
    My opinion? The ORP wheels look great on white. And the gray Pro wheels look even better.
    I'm not a fan of black wheels all the time, particularly on white. Looks like wearing white gym shorts and black shoes, y'know?
    When I was shopping for mine, somebody around here posted a pic of a white T4R with the gray Pro wheels. I was sold. :cool:
    ETA: I can't say keeping both sets is a bad idea. One set dedicated for good weather, the other set for bad.
  14. Dec 1, 2025 at 8:25 PM
    I hand wash the truck but only rinse off the wheels. Clean and shiny rims is a tell tell sign it’s a tourist that never leaves the pavement. ;)
  15. Dec 2, 2025 at 9:27 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    We have a Nautical Blue 4R bought new '16 and the some of the reasons that I choose the Matte Gray were that quite a few around here have shiny or black. I think that the black gets lost against the NB so we choose the Matte Gray. But probably the best reason is that my Wife is a great negotiator and she got the price on the MG wheels down to $60 per wheel when she was talking with sales and financing Ladies. I just played the part of the Husband in the corner wanting more eye candy.
    I still have the stock shiny Trail Premium wheels & worn out Dunflop's. They only lasted 12,000 miles.
    Imdav2u likes this.
  16. Dec 2, 2025 at 10:23 AM
    Based on this thread (Naughty blue) I vote for ORP wheels...
  17. Dec 2, 2025 at 10:35 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    I liked the way they look. At this time it is a mall crawling garage queen w/12K miles in 3yrs, I’ve got other toys to beat on. I have better tires since this photo which is the only change since new.IMG_2187.jpg
  18. Dec 2, 2025 at 10:37 AM
    Imdav2u
    23 TRD PRO
    I like the gray wheels on a blue 4runner. My buddy has a Nautical Blue, he has the factory chrome, not a big fan.
  19. Dec 2, 2025 at 11:14 AM
    For Army green, MGM, Orange ,etc I think black wheels with black valance would looks good.
    2ndGen22re[QUOTED] likes this.
  20. Dec 2, 2025 at 11:26 AM
    MWinkTRD
    MWinkTRD Basically Stock
    Max
    Southeast Alabama
    2023 MGM TRD ORP
    +1 for the TRD Off-Road wheels. Never been a fan of all black wheels (looks like missing hubcaps imo if there’s no accenting) and the machined spokes on the OR wheels is enough “bling” to contrast the magnetic gray and match the other silver accents that’s on the truck.
    carb434, Curlystooge, 2Toys and 6 others like this.
  21. Dec 2, 2025 at 11:32 AM
    Dang that looks good. :101010:
    MWinkTRD[QUOTED] likes this.
  22. Dec 2, 2025 at 11:36 AM
    evanspen
    evanspen New Member
    1995 red limited 4runner
    Personally I love the ORP wheels. We run them on 2 pre face lifts 5th gen runners and my first gen tacoma. They look good on almost anything and are one of the better wheels out there.
  23. Dec 2, 2025 at 11:39 AM
    MWinkTRD
    Max
    Southeast Alabama
    2023 MGM TRD ORP
    Thank you! 1” front leveling kit and stock sized R/T tires was all that was missing for me. Been on this setup 2.5 years with zero issues or complaints
    kmeeg[QUOTED] likes this.
  24. Dec 2, 2025 at 12:29 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    The pro wheels are 7" wide vs 7 1/2" for the ORP's. The extra 1/2" opens up more tire options. The ORP wheels also have, as @kmeeg mentioned, the valve stem is well protected. If you only crawl at the mall, get what you like. If you do any semi-serious off roading, the ORP's are probably a better choice. It really sucks to get a flat from a pulled out valve.
  25. Dec 2, 2025 at 12:46 PM
    S8ULATR
    S8ULATR New Member
    2 Germans, a Beast, a Jeep, lotsa dogs
    +1 for the Off Road wheels. The Pro ones, and this is just my opinion, give Bro Pro vibes and while they are a nice looking wheel, they are very played out (at least where I live). I really like the look of Method whels on 4R's.
  26. Dec 2, 2025 at 12:56 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    There's at least one other thread on the differences and benefits.
    If you care about my opinion, it is that the OR wheels are better - they are wider and feature a valve stem guard, so they fit a bigger range of tires and they better protect the valve stem off-road.
    I personally think they look great too, but I will allow that is subjective.
    I sought out some to replace my OEM 19" Lexus trash... new emblem and I was GTG...
  27. Dec 2, 2025 at 12:56 PM
    Daddykool
    My favorite wheel on a 4R is the OR wheel. It looks good on every color 4Runner. Other wheels tend to look good on certain colors. And they are extremely easy to clean. I use Turtle Ice spray wax and a microfiber cloth, and it literally takes me 3 minutes per wheel to have them shiny again (rinse them first). The wax gets the brake dust off as well. The 1/2" extra width and valve stem protection are pluses that I was unaware of.
  28. Dec 2, 2025 at 1:16 PM
    Agreed. Wheels, badges, and valances balance out perfectly, especially on an MGM 4R.
  29. Dec 2, 2025 at 1:18 PM
    Captain Sensible
    Captain Sensible New Member
    I have a '23 ORP. When I went to pick it up there was an apology sticker on the window saying, we ran out of ORP wheels and had to give you pro wheels. Well hell, thank you toyota, you just saved me a couple grand in aftermarket rims! And yes, I did get the black replacement lug nuts.
  30. Dec 2, 2025 at 4:33 PM
    2ndGen22re
    CR
    Carson Valley, NV
    I have thought about that since new but now I think I would go body color.
