TRD Pro Rack Removal
Discussion in '5th Gen 4Runners (2010-2024)' started by coachhomer, Nov 25, 2024.
  1. Nov 25, 2024 at 8:29 AM
    coachhomer
    coachhomer [OP] New Member
    Good morning. Who has had success removing the rack? I tried using a soldering gun on the bolt but that didn’t have any luck on the Loctite. So then I tried a propane torch but that destroyed the plastic housing around the screws. How do you get the screws out without melting the base plate?
  2. Nov 25, 2024 at 9:06 AM
    Up, down and all around!
    I was fortunate just a little bit more elbow grease and patience applying constant pressure released all the bolts on my rack. An impact driver would also be your friend.
  3. Nov 25, 2024 at 9:16 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Do you have a heat gun?
    really the only way is to loosen the red loctite. Its a bitch
  4. Nov 25, 2024 at 9:40 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    SEPA
    2023 PRO
    This! But no impact driver. I removed mine a few weeks ago. The bolts get pretty hot when turning, just keep going slow
  5. Nov 25, 2024 at 9:48 AM
    coachhomer
    Thanks all. I was able to get them off with use of a heat gun or torch. Best advice I saw was leave it in the sun for a few hours. They seemed to loosen up but I did take it slow. Thanks again!
