TRD Pro Grill Install Issues
Discussion in 'General 4Runner Talk' started by T4R_Lara, Apr 3, 2023.
  1. Apr 3, 2023 at 11:57 AM
    T4R_Lara
    T4R_Lara [OP] New Member
    2022 TRD ORP
    Bilstein 6112's w/UCA's up front, 5100's rear, MR312 matte black, Falken Wildpeak AT3's
    So, i'm having some issues with the 3M double sided tape on my TRD Pro grill install. The tape keeps coming off. The surface is clean and i've heated the tape up, but it just keeps peeling off. Thinking of using some windshield glue lol but not sure how I would keep pressure on it long enough to cure. Any suggestions are appreciated!
  2. Apr 4, 2023 at 4:06 PM
    travelinscout
    travelinscout New Member
    2020 TRD ORP MGM
    What kit did you buy? I ended redoing all of my 3M tape with about 3 times as much as it came with. Its been on about a year so far, and hasn't moved. When you say coming off, do you mean coming off the truck side or the grill piece side? You may need to rough it up slightly to get it to stick.
  3. Apr 5, 2023 at 1:37 PM
    asanner
    asanner New Member
    2022 4Runner ORP
    I added more tape to mine as well. The sides still don’t sit perfect but I’ve seen factory kits the same way.
  4. Apr 10, 2023 at 9:56 AM
    Connor MacLeod
    Connor MacLeod New Member
    Connor
    2023 TRD Off Road
    Not sure if it would help for taping this particular part, but you might try sanding the surface that you need to tape with something like a 220-grit sandpaper if the original surface was somewhat non-stick.
  5. May 3, 2023 at 2:16 PM
    T4R_Lara
    2022 TRD ORP
    I purchased the grill from Overland Depot. The 3M tape provided was not nearly enough nor strong enough. I ended up purchasing the strongest grade 3M tape and used a ton of it to get the grill to conform and stick properly to the body. It is still not completely flush at both ends, but pretty damn good for now. Let's see how she holds up over time. I was tempted to use windshield glue, but couldn't figure out a way to keep it compressed up against the body while the glue cured.
  6. May 6, 2023 at 1:48 PM
    asanner
    asanner New Member
    2022 4Runner ORP
    I had to add more tape to mine as well.
  7. May 6, 2023 at 4:27 PM
    Windplr
    Windplr New Member
    Coos Bay, Oregon
    2022 ORP Lunar Rock
    After market, or OEM? I've heard the tape on some of the after market ones may not be of the highest quality. I installed an oem Pro grill and I got a very secure fit with the tape that it came with. I also wiped the original grille with rubbing alcohol.
  8. Aug 19, 2023 at 9:47 AM
    Awyeah
    Awyeah Whitewater Forever (brown claw send it)
    Austin
    4Runner SR5 Premium 4X4
    Heritage grille, raptor lights, NERF bars, Yakima cross bars, Tri Color 10,000 lumen Fog Lamps, LASFIT backup and interior LEDs.
    What tape did you buy? I am dealing with the same issue. Not as concerned about perfect flush as I am the grille flying off.
