TRD oil filter officially discontinued by Toyota?
Discussion in '5th Gen 4Runners (2010-2024)' started by MI4runner2014, May 21, 2024.
  1. May 21, 2024 at 4:46 PM
    MI4runner2014
    MI4runner2014 [OP] New Member
    I have been told from a local Toyota dealer that Toyota has officially discontinued PTR4300079 and if people are able to order it’s only remaining stock they have.
    Does anyone know if Toyota will be offering a new premium oil filter?
    I know the standard oil filter is just fine but I like the idea of a better sealing, less restricted premium oil filter. Thanks if anyone knows. I know Amsoil makes one but it’s similar in style to the one which Toyota has discontinued and I wonder now for what reason they discontinued, maybe this design is no longer seen by Toyota as properly filtering the oil? Or maybe it just didn’t sell well?
  2. May 21, 2024 at 4:51 PM
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
    Buy the Amsoil. They made the TRD filter.
    jgalt and MI4runner2014[OP] like this.
  3. May 21, 2024 at 4:58 PM
    MI4runner2014
    I wonder if they were discontinued because of a design flaw by Toyota? Assuming not. Not that they would officially admit this. I’ve used the Amsoil one which used to be made in USA but I’ve noticed the last two I ordered have said made in Mexico . Also noticed the black sealing adhesive covering up some of the slots that the oil is supposed to flow through with the Mexico made ones. Sad they changed the country of manufacture.
    jgalt and CJT4Runner[QUOTED] like this.
  4. May 21, 2024 at 5:00 PM
    Most likely it was a disagreement about money i.e. Amsoil wanted a higher dollar amount for each filter and Toyota refused.
    Too Stroked likes this.
  5. May 21, 2024 at 5:00 PM
    I’m thinking it just didn’t sell. People will buy Toyota oil just because it says Toyota but they won’t spend more on a better filter.
  6. May 21, 2024 at 6:25 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Is it really that much better? Like more than $35 better than this? Show me the proof. IMG_0291.jpg
  7. May 21, 2024 at 7:30 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Can’t be 35$ better at 3-5k interval changes.
  8. May 21, 2024 at 7:40 PM
    I mean people fap over the Toyota branded oil because they think it’s better. MoRe MoLy
  9. May 22, 2024 at 5:13 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    +1.
    Also consider when it comes to any kind of filter, in general "better flow" and "better filtering" are mutually exclusive. Unless the engine had some known oil starvation issues (which it doesn't), I wouldn't give up filtering ability to get more flow just for bragging rights. Especially if these are the same people changing oil every 1000 miles because they are afraid the engine wont last :D
    LCJ77, MeefZah and Acesandeights like this.
  10. May 22, 2024 at 1:42 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    This, I will stick to paying $7 for OE filters from my local dealer. They even throw in free drain plug gaskets for me.
  11. May 22, 2024 at 1:54 PM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
  12. May 22, 2024 at 2:51 PM
    2016Pro
    I have never used them, I get filters that are rated to at least 15k. Works fine
  13. May 22, 2024 at 3:55 PM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    actually seems to indicate the Toyota filter did the least filtering. It just flowed better..
    I’m kinda dissapointed because then I owned my Taco everybody on Tacomaworld raved about the OEM being the best, so that’s what I used. Before the Taco I tended to use mostly Bosch and Mobil1
    2016Pro likes this.
  14. May 23, 2024 at 5:15 AM
    ^Does anybody know the opening pressure of the bypass valve in the 1GR filter cap? Greater filtering efficiency is wasted and even counterproductive if the higher pressure buildup causes the bypass valve to open more often.
  15. May 23, 2024 at 10:49 AM
    2016Pro
    Nah, zero interest in this information. Doesn't matter
    MeefZah likes this.
  16. May 23, 2024 at 10:58 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Right. The engineers have that all figured out to work with the OEM filter. Which is why I'll spend the $7.
  17. May 23, 2024 at 11:07 AM
    2016Pro
    Lol ok
  18. Aug 24, 2024 at 8:24 PM
    keys21
    keys21 New Member
    5th gen ‘21 ORP 90k or so
    I’ve been using AMSOIL fluid for years, the TRD filters not only had better filtration due to the medium, but they also sealed from the top and bottom not allowing any fluid to leak past the filter. That is an issue that has been tested and proven as a failure point in all of these canister style filters that Toyota utilizes with factory standard filter inserts. We can say that it’s fine all we want, but the fact of the matter is the TRD filters with rubber rings top and bottom provide 100% seal for filtration and virtually every other Brand of car using filters like this has rubber gaskets on both end of the filter itself. Toyota decides to get rid of this thing, I confirmed with multiple dealers, and AMSOIL is selling it for 35. I can promise you that AMSOIL is not the manufacturer of the TRD filter, not sure about their own. Consider skipping the filter from AMSOIL. They literally fall apart, every single one I’ve been getting either has improperly seated red O-rings top and bottom, ripped material on the outside, in this case, and I had black glue pieces, chunks in between the pleats that when removed ripped the filter. The seam was also coming apart and looks like it was sewn together by a three-year-old, literally pieces of plastic falling into my hand. I had to go to Walmart to get some fram filter. I don’t know what I will do going forward, I know some dealers in Saudi Arabia stocked these, I will order a large batch if I can and post here. Literally created an account just to tell folks to stop ordering, AMSOIL refunded me for the last two that I ordered. They make fluids - not filters, to my knowledge. If you can’t find or order one with rubber seals top and bottom with metal cap plates on both ends, stick with Walmart Fram
    FRAM Ultra Synthetic®
    XG10158 Engine Oil Filter
    IMG_1228.jpg IMG_1229.jpg IMG_1228.jpg IMG_1229.jpg IMG_1228.jpg IMG_1229.jpg
  19. Aug 24, 2024 at 8:32 PM
    MI4runner2014
    You are correct the newer Amsoil ones are not the same…these are made in Mexico. However, the older Amsoil ones were in fact made by the same manufacturer (made in the USA) that the TRD ones were…both were of high quality. However, the newer Amsoil ones are HORRIBLE! I agree with you about the newer ones and have seen the same flaws you point out. Should you find a good replacement, not the stock Toyota one, please let us know.
    keys21[QUOTED] likes this.
  20. Aug 24, 2024 at 8:34 PM
    keys21
    keys21 New Member
    Will do! Search begins!
  21. Aug 24, 2024 at 8:43 PM
    keys21
    keys21 New Member
  22. Aug 24, 2024 at 8:47 PM
    keys21
    keys21 New Member
  23. Aug 24, 2024 at 8:56 PM
    keys21
    keys21 New Member
    Or we finally stop with these messy canister filters and convert to commonly available 2 min changeable screw ons. I have avoided this baxter style adapter as I was worried that pump flow wouldn’t be the same as the spring in the OEM housing has a certain amount of pressure that allows for flow
    Thoughts?
    https://www.northridge4x4.com/part/...oyota-cartridge-to-spin-on-oil-filter-adapter
  24. Aug 24, 2024 at 9:00 PM
    keys21
    keys21 New Member
    So apparently Baxter accounted for this with a spring loaded setup as well, using the same viton style gasket rubber that Toyota used for TRD as described on their Japan parts site
    Liking it so far..
    https://www.baxterperformanceusa.co...k-cartridge-to-spin-on-adapter-universal.html
  25. Aug 24, 2024 at 9:02 PM
    keys21
    keys21 New Member
  26. Aug 27, 2024 at 8:33 PM
    MI4runner2014
    Sadly the newer Royal Purple filters are made in Mexico by whomever makes the new horrible Amsoil ones. Both brands used to be made in USA.
  27. Aug 28, 2024 at 3:38 AM
    keys21
    keys21 New Member
    So looks like I’ll be looking at the filter conversion kit most likely then… The filter media is really garbage to be honest, or we just go with the cheap Toyota filters and stop worrying about it
  28. Aug 28, 2024 at 8:26 AM
    2016Pro
    Just use toyota filters your vehicle will outlast your ownership
    bigshmoop and whippersnapper02 like this.
  29. Aug 28, 2024 at 10:57 AM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    I've been curious about that adapter but:
    1) The price
    2) I hesitate to deviate too much from Toyota engineering
    3) The price...
  30. Aug 28, 2024 at 11:11 AM
    It's a solution for something that isn't a problem. Plus I don't think you can run the OEM skid with it.
