Trany won't shift out of first
Discussion in '2nd Gen 4Runners (1990-1995)' started by Kazter Troy, Jul 24, 2020.
  1. Jul 24, 2020 at 7:42 AM
    Kazter Troy
    Kazter Troy [OP] New Member
    95 v6 4x4 z
    Hey everyone. I just picked up on a '95 v6 4x4 with 173,000 miles. She looks new. All original. Old lady sold it because her husband had a stroke 10 years ago and it's been parked from that day. I took about a gallon of tar like stuff out of tank flushed everything. Injectors we're clogged. Replaced those with 4hole up grades. Now my trany won't shift out of 1st.
  2. Jul 24, 2020 at 7:46 AM
    Kazter Troy
    95 v6 4x4 z
    Oh. I found some rat wires on top the tranny and found the receipt for a trany solenoid. Popped the pan. Fluid looks new. Smells not exactly right. I think the wires go to the speed sensor drivers sidejsidejust in front of the transfer case.
  3. Jul 24, 2020 at 7:55 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    I was going to say you have a bad sensor. I had one go out and it wouldn't shift out of first. Has it thrown any codes?
  4. Jul 24, 2020 at 8:15 PM
    Kazter Troy
    95 v6 4x4 z
    No codes. I'm kinda suspicious about that. Even the clogged injectors didn't pop a code. I tried the paper clip trick and still nothing..but the computer is working or the new injectors wouldn't work right? I check before I installed them. It's getting a pulse signal. Right on top of the tranny I found two wires the rats clipped. I think the speed sensor. Are the ECU and tranny computer two separate devices?
  5. Jul 30, 2020 at 6:46 AM
    Kazter Troy
    95 v6 4x4 z
    Ok. Well I guess I'm going to pull the computer out and have a gander at it. I have multiple issues and getting no code. Leads me to suspect computer problems. Also going to air check the solenoids and check the throttle position sensor. Anyone have any other ideas about the no upshift issue?
