Transmission leaking and question
Discussion in '3rd Gen 4Runners (1996-2002)' started by Teamninja, Nov 2, 2018.
  1. Nov 2, 2018 at 6:33 PM
    Teamninja
    Teamninja [OP] New Member
    Kinder
    2000 4Runner Limited
    still stock except Satoshi Grill. Plans on lifting and armor
    I have a 2000 4runner limited and my transmission is leaking fast from where it bolts up to the motor. Transmission shifts and drives fine but the fluid is just pissing out, what could that possibly be?
    I also found a transmission from a 2000 4runner sr5 and wanted to know if it will work with the limited model if this is a problem that is not repairable.
  2. Nov 2, 2018 at 6:38 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
  3. Nov 3, 2018 at 6:28 AM
    COexplorer
    COexplorer New Member
    Graham
    2018 TRD Off Road
    Are you sure it is transmission fluid and not engine oil? Could be the main seal around your cranksharft. Main seal will also leak from where it bolts to the engine block.
  4. Nov 3, 2018 at 7:33 AM
    Teamninja
    Kinder
    Its transmission fluid, tranny was starting to slip and not engage as i was getting closer to home as soon as i noticed i was pissing away fluid.
  5. Nov 3, 2018 at 7:32 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Is it common for a trans seal to blow suddenly like that?
  6. Nov 4, 2018 at 8:42 AM
    Toyotayoda
    Toyotayoda New Member
    Atlanta area
    1997 SR5 4x4, 302k and counting
    Tacoma whip, 99 console box, tru trac., steering wheel, PWMS and HVAC control out of a 99.
    definitely agree on the torque converter seal, repair can be simple, remove the trans and inspect the drive plate/flywheel also check for for free play of the torque converter where it fits into the front pump. The torque converter shouldn't have a whole lot of movement in the trans, if there is too much movement replacing the seal will be a short lived band-aid.
