Transmission hose
Discussion in '4th Gen 4Runners (2003-2009)' started by Rockhoundrob, Apr 20, 2023.
  1. Apr 20, 2023 at 10:48 AM
    Rockhoundrob
    Rockhoundrob [OP] New Member
    2006 4Runner
    My son pretty much overhauled his 2006 4Runner.
    He replaced the steel pair transmission hose at the bottom of the radiator.
    The old flexible hose from this to the radiator on the driver side was brittle, so we replaced it with flexible tube from an auto store because this hose was about $80 from Toyota on line.
    Part# 3294260390.
    After several weeks of driving, we noticed a kink in this hose. The kink was cause by the bend going into the radiator. Is there a way around this "bend"? The factory hose is almost L-shaped.
    We are thinking of cutting the hose and get a metal L-tube and splice it. will this work?
    Does anyone have another way around this or other tried and true ideas?
    Pomchi likes this.
  2. Apr 20, 2023 at 6:19 PM
    Rockhoundrob
    2006 4Runner
    Never mind this. I found 1 on eBay (new) for $35. I'll take a chance here.
    Pomchi likes this.
  3. Apr 20, 2023 at 7:19 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    You had the right idea if not using a factory, pre-molded hose. I'd have done the L tube option too. No problems with doing that as long as it doesn't leak.
  4. May 7, 2023 at 12:13 PM
    Pomchi
    Pomchi New Member
    Ed
    2005 4.0 v6 4x4 SR5
    Can you send a link to the part you found on ebay for $35? Thank you.
  5. May 10, 2023 at 1:40 PM
    Rockhoundrob
    2006 4Runner
