Transmission fluid cooler inlet/outlet
Discussion in '4th Gen 4Runners (2003-2009)' started by RUNERLUVER, Mar 15, 2024.
  1. Mar 15, 2024 at 5:10 PM
    RUNERLUVER
    RUNERLUVER [OP] New Member
    2003 Limited 4.7
    Hello! I'm about to do a DIY tranny fluid flush and fill on my '03 limited w/4.7. Can anyone confirm the fluid flow direction thru the cooler mounted in front of the radiator? I'm assuming
    the bottom is inlet but that's using common sense which sometimes doesn't apply. (see US Government) Anyway, I 'm hoping to get some help. Thanks!
  2. Mar 15, 2024 at 6:01 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    You have a 2003, just drain from the pan and refill from the dip stick. The cooler method is slow as shit, sucks doing and isn't necessary with the 03 or 04 since they have a trans dipstick.
  3. Mar 16, 2024 at 5:17 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    I'm not sure which line is the correct line at the cooler, but linked below is a topic that tells you which line is which back at the transmission, you can then follow the lines to the cooler to know which line to use.
    Note: Just an FYI his is a 2004 V8, which has the sealed transmission, your 2003 is not the sealed transmission but otherwise should be much the same as the sealed one but there could be differences, the other difference if I'm not mistaken is the non-sealed 5 speed uses the older ATF and not the WS ATF, just be sure you use the correct ATF!
    xtremewlr likes this.
  4. Mar 16, 2024 at 2:06 PM
    xtremewlr
    Todd
    Tucson, AZ
    I probably always get it wrong but I could have sworn the 04 also had the dipstick. My bad.
    But, he said he has an 03. So i would skip the cooling line exchange for that still.
  5. Mar 16, 2024 at 2:13 PM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    He says a "flush" you can't do a flush simply draining the pan, only a "drain and fill", you need to exchange all the fluid, the best way to do that is via the lines, he can still fill thru the dip stick tube.
    The 2003 V8 and V6 has a dip stick, the 2004 V6 does as well, the 2004 V8 however is the first application in a T4R of the sealed 5 speed transmission, all engines V6s and V8s after that has the sealed transmission.
  6. Mar 18, 2024 at 4:36 AM
    frosty
    frosty Stay Frosty
    Daniel
    DFW, Texas
    2004 4Runner V6 SR5 2WD
    My 04 V6 has a dipstick for the trans.
