Transmission Filter... to replace, or not replace?
Discussion in '4th Gen 4Runners (2003-2009)' started by DerrHarr, Sep 4, 2024.
  1. Sep 4, 2024 at 10:23 AM
    DerrHarr
    DerrHarr [OP] New Member
    Just bought an '07 V6 with 196k on it. Going through all the major tuneups, including changing the trans fluid. Wanted to ask you guys, without any knowledge of it's previous service history, would you also replace the trans filter? Or leave it be? Thanks in advance
    Note: the fluid doesn't smell bad currently, and is not overly dark. No shifting problems to speak of.
  2. Sep 4, 2024 at 10:57 AM
    LaHh
    LaHh New Member
    It’s just a metal mesh screen. If I’m replacing the transmission gasket, I would replace it since it’s already opened. But if I’m just replacing the fluids, nope.
    3JOH22A and icebear like this.
  3. Sep 4, 2024 at 11:04 AM
    Sailormilan2
    Sailormilan2 New Member
    Dale
    2020 4Runner TRD Premium
    The pan “filter” is just a screen. I wouldn’t plan on replacing, or cleaning it. If I was just doing the fluids, I would install an inline transmission filter on the return line from the radiator. They’re good for about 30K miles. I use one on my Tacoma, will put one on my 4Runner.
    The fluid on my Tacoma went from a very dark cherry red to a red color. So, it does work.
    Besides, it’s a lot easier to change an inline filter than to drop the transmission pan to mess with the internal “filter”(screen).
  4. Sep 4, 2024 at 11:14 AM
    DerrHarr
    That's brilliant. And good to know.
  5. Sep 4, 2024 at 8:05 PM
    RepentOrPerish
    RepentOrPerish New Member
    4thGenv8
    I have an apt Friday for a drain and fill. 2006 with 165000. Toyota service guy didnt recommend anything other than that.
    Makes me a bit nervous even having it done. Just as soon would have tackled it myself but without a damn dipstick its seems too much of a mess checking the level.
  6. Sep 5, 2024 at 7:39 AM
    DerrHarr
    That is true, I have no idea why they didn't add a dipstick... it does make it a pain.
  7. Sep 5, 2024 at 8:47 AM
    RepentOrPerish
    4thGenv8
    Yeah instead of adding, they took it away! Lol the earlier models all had one from what ive read.
  8. Sep 5, 2024 at 8:55 AM
    If you have another reason to drop the pan (e.g. gasket leaking or pan rusted through), replace the filter on opportunity. Otherwise I'd leave it. I didn't replace the filter when I did a drain & fill on my 2010 last year, same A750 transmission as yours.
  9. Sep 5, 2024 at 3:46 PM
    TRDSD
    2019 TRD Off Road Premium
    You'll be fine with a drain and fill. It's a good recommendation. Better to get 4ish quarts of new fluid mixed in vs. nothing at all.
  10. Sep 7, 2024 at 2:39 PM
    RepentOrPerish
    4thGenv8
    All seemed to go well. Transmission didnt drop out on the way home at least...
  11. Sep 7, 2024 at 7:18 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Glad to hear it worked out. What did they charge, if you don’t mind sharing?
  12. Sep 7, 2024 at 8:26 PM
    RepentOrPerish
    4thGenv8
    Approx 135
    Bluesky 07 likes this.
