Transmission cooler rubber lines
Discussion in '4th Gen 4Runners (2003-2009)' started by artfil91, Nov 20, 2022.
  1. Nov 20, 2022 at 6:37 PM
    artfil91
    artfil91 [OP] New Member
    Arthur
    2003 Black SR5 4Runner V6 4x4
    Hi guys, I got a 2003 4Runner 4x4 SR5 V6 and I'm currently replacing ALL my transmission cooler lines and I'm wondering if there are any alternatives to the OEM rubber hoses.
    I'm curious to see if anybody found this rubber hose in bulk/cut to length, if so what are the specs on it? I'm referring to the rubber hoses between both sets of hardlines and the radiator in the pic below:
  2. Nov 21, 2022 at 6:24 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    When i upgraded my trans cooler used this exact line: https://www.amazon.com/Hayden-Automotive-106-Transmission-Cooler/dp/B000HE6H3S/
    It worked perfectly since doing the swap in 2019. Biggest thing to pay attention to is the internal diameter of the hose, as you dont want to happen to get something narrower than what you currently have and create a flow restriction. Pretty sure its 3/8" ID, but probably double check with some calipers.
  3. Nov 21, 2022 at 7:36 AM
    artfil91
    Arthur
    OMG that is EXACTLY what I was looking for! Thank you so much. That 4 ft section is cheaper than 1 of those rubber hoses from the dealership.
