Transmission cooler question
Discussion in '5th Gen 4Runners (2010-2024)' started by TRD5thgenner, Mar 30, 2025.
  1. Mar 30, 2025 at 4:55 PM
    TRD5thgenner
    TRD5thgenner [OP] Not Very Well Known Member
    2021 4runner TRD Offroad Premium
    Im planning on adding a aftermarket transmission cooler to my 21 5th gen. Do I need to purge out air from the transmission lines like I would if I bled the brakes or purged air from the cooling system?
    If so how do I go about getting air out of the lines?
  2. Mar 30, 2025 at 5:21 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited
    OME Nitrocharger struts and shocks. OME 884X front springs, OME 889X rear springs, full RCI skids, RCI roof rack, RCI sliders with kickouts, Method Racing MR306 Mesh wheels.
    If everything is hooked up correctly, you shouldn't have to do anything other than potentially add some transmission fluid to accommodate for the extra hoses and cooler.
    RumHamRunner73 likes this.
  3. Mar 30, 2025 at 5:33 PM
    TRD5thgenner
    Okay, so no worries about potential trapped air?
  4. Mar 30, 2025 at 5:53 PM
    Just out of curiosity, why are you adding a trans cooler?
  5. Mar 30, 2025 at 6:04 PM
    catbrown357
    Tempe
    2011 Limited
    It's not really a "closed" system like your cooling system or brake lines. The pump should be able to circulate fluid to anything connected. You'll probably need to cycle through the gears a few times initially to get fully circulated. From there it's going to be like checking and adding fluid. Bring it up to recommended temperature and add fluid as needed. I'd bet it's less than a quart. https://www.youtube.com/watch?v=zS8rqg1PVwU
  6. Mar 30, 2025 at 7:37 PM
    TRD5thgenner
    Towing a 2,700 lb trailer
  7. Mar 30, 2025 at 8:16 PM
    2019 TRDP w/Kangs brah!
  8. Mar 30, 2025 at 8:42 PM
    TRD5thgenner
