Transmission capacity
Discussion in '3rd Gen 4Runners (1996-2002)' started by KamaDeva, Dec 3, 2020.
  1. Dec 3, 2020 at 8:26 AM
    KamaDeva
    KamaDeva [OP] New Member
    Carrie
    2001 4Runner
    Can someone please verify the total amount of transmission fluid that is needed for a full flush and replace? The Manuel only shows for a drain and fill. I have researched and somehow I have written down 2 different answers. So, which is it...8qts or 16qts? I plan on doing the cycles to rid of all old fluid and replacing filter/gasket.
  2. Dec 3, 2020 at 8:55 AM
    If you are doing the fill/drain/fill/drain dance through the transmission cooler line, mine was closer to 16Quarts before it started going red.
