transmissio drops into 4lo at random
Discussion in '5th Gen 4Runners (2010-2024)' started by AlbertG, Apr 4, 2026.
  1. Apr 4, 2026 at 2:14 PM
    AlbertG
    AlbertG [OP] New Member
    2015 4Runner
    2015 4Runner - at random the 4lo, chk engine, Trak Off light goes on, the shifter resists moving, the cruise goes off, the real washer and wiper doesnt work. Then after a few days or overnight all just disappears. also the transmission actually runs in 4Lo. I've seen some older posts on this none that direct to the actual issue. Before I bring it in i could use some help.
  2. Apr 4, 2026 at 2:56 PM
    2019 TRDP w/Kangs brah!
    The transmission doesn’t go into 4low, the transfer case does. Read the stored code and work from there.
  3. Apr 4, 2026 at 3:19 PM
    22 ORP
    Hi Albert. Welcome to the forum. So the title of your topic says that the truck is shifting into 4LO by itself. But in your first post you describe a bunch of lights coming on, including the 4Lo light. It’s basically impossible for the transfer case to shift into 4Lo “at random”. The transmission has to be in neutral, etc.
    So can we assume that your transfer case is not shifting itself at random, and what you are actually reporting is lights on your instrument cluster illuminating at random?
  4. Apr 4, 2026 at 5:57 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
  5. Apr 4, 2026 at 6:45 PM
    AlbertG
    2015 4Runner
    Yes all the lights go on with thd other symptoms mentioned and simultaneously the transmission goes into 4lo. At 70mph my tach would usually be 2k. When it switches to 4lo the tach is at 3k.
  6. Apr 4, 2026 at 6:47 PM
    As stated in post #2, a 4R transmission doesn't have a 4lo. Only the transfer case does. So whatever your transmission is doing, it's not going into 4lo.
    Saker, 2Toys and TrailSpecial22 like this.
  7. Apr 4, 2026 at 7:09 PM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    I may be wrong but can you even hit 70 in 4low?
    Saker, 2Toys and FourBelugas like this.
  8. Apr 4, 2026 at 7:25 PM
    FourBelugas
    23 white ORP
    I don't think so. I think I read somewhere on this site it maxes out around 50mph in 5th gear or something.
    In any case the vehicle is not shifting into 4Lo at freeway speeds. the neutral safety switch is there for a reason. If that actually happened due to a series of glitches, the driver would DEFINITELY know it happened because the vehicle won't let you ignore the symptoms.
    NB4x4[QUOTED] likes this.
  9. Apr 4, 2026 at 7:45 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @AlbertG I’ve had dash light up in similar ways before maybe truck had gone into limp home mode and rpm’s increase cuz youre stuck in 2nd or 3rd gear.
    NB4x4 likes this.
  10. Apr 4, 2026 at 7:52 PM
    I think you’re right, and I think 4lo caps in 4th gear
  11. Apr 4, 2026 at 8:06 PM
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    Are you sure it’s not S4? That’s not a massive RPM jump.
  12. Apr 4, 2026 at 8:07 PM
    Sounds like the transmission is just downshifting a gear…5th to 4th. I would have the battery tested because that can cause a bunch of weird issues. Also read that code.
  13. Apr 4, 2026 at 9:04 PM
    FourBelugas
    23 white ORP
    That does ring a bell.
    NB4x4 likes this.
  14. Apr 4, 2026 at 9:55 PM
    UncleShorty
    UncleShorty New Member
    I'm no expert, haven't used 4 low for years. But at 70 mph dropping into 4 low there'd be hair and eyeballs all over the windshield from the almost instantaneous drop in speed.
    One thousand rpm increase? Baloney, there'd be pistons passing Artimis...
    McSpazatron, Saker, 2Toys and 4 others like this.
  15. Apr 5, 2026 at 12:11 AM
    Yamahamer
    Yamahamer New Member
    Nevada
    2022 4Runner Off Road
    ^This is what is going on. Transmission is shifting out of Overdrive (5th gear) to direct drive (4th gear). Mine does that all the time on the steep hills we have around here and that's how much the tach jumps up - about 1000 rpm. No possible way for the transfer case to shift itself into Lo Range at 70 mph - there would be gears and other parts scattered all over the road if that were to occur.
  16. Apr 5, 2026 at 4:38 AM
    AlbertG
    2015 4Runner
    The shift to 4lo (light) and all the other symptoms happens at startup not while driving.
  17. Apr 5, 2026 at 5:11 AM
    Welcome from Wisconsin! Did you try a code reader to check for codes? It may be a software/electrical problem, the code reader may help, also could be your 'actuator' for 4WD, another thing to try is disconnecting the battery to try a 'reset'. Good luck.
  18. Apr 5, 2026 at 10:50 AM
    if it was 4lo you would be 6000+rpms and you would stop almost instantly and shit would frag. Sounds like its dropping into 4th gear from 5th not 4 Low.
    Saker, NB4x4 and banjos-n-beer like this.
  19. Apr 5, 2026 at 10:51 AM
    No
  20. Apr 5, 2026 at 10:58 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Yeah. Stuff would detonate. If it could even enter that mode.
    NB4x4 likes this.
  21. Apr 5, 2026 at 3:16 PM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    This thread is starting to remind me of another where we wasted pages and hours trying to help out a troll. We have a 2k to 3k rpm increase at 70 MPH when downshifting from 5 to 4, and dash lights illuminating on startup. Nothing is unusual
  22. Apr 5, 2026 at 3:47 PM
    ^ correct
    At 70 mph in 5th mine with 33”s is about 1900-2000. 4th gear is about 2700-2800.
    NB4x4 and banjos-n-beer[QUOTED] like this.
  23. Apr 5, 2026 at 3:48 PM
    wouldn’t that be wild if the post is like a riddle written by a troll. sometimes trolls don’t return and don’t engage. OP checked-in this AM
    NB4x4 and TrailSpecial22 like this.
  24. Apr 5, 2026 at 3:49 PM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Maybe it’s a bot designed to initiate engagement. But it’s a bunk post with moving goal posts.
  25. Apr 6, 2026 at 10:19 AM
    AlbertG
    2015 4Runner
    Time to terminate the thread. Thanks all.
    TrailSpecial22 and Saker like this.
  26. Apr 6, 2026 at 1:13 PM
    :popcorn:
    2Toys, TrailSpecial22 and NB4x4 like this.
  27. Apr 6, 2026 at 1:23 PM
    so what was the outcome or was this thread a complete waste of time?
  28. Apr 6, 2026 at 2:23 PM
  29. Apr 7, 2026 at 3:14 AM
    The outcome: we now know that in 4LO @ 70mph we'll be turning between 6,000 and 7,000 RPM... unexpected left turn?
