Transfer case shifter
Discussion in '5th Gen 4Runners (2010-2024)' started by frostytrd, Sep 15, 2023.
  1. Sep 15, 2023 at 8:28 AM
    frostytrd
    frostytrd [OP] New Member
    Does anyone else’s transfer case shifter shake and vibrate while driving??
  2. Sep 15, 2023 at 8:30 AM
    Yes. It’s connected directly to the drivetrain which moves as you drive.
  3. Sep 15, 2023 at 8:35 AM
    Ha ha, sometimes when I'm bored I keep my hand on it and enjoy the feeling how the vibration intensity changes with the revs. :p
  4. Sep 15, 2023 at 8:36 AM
    Yes, everyone's does.
    ^^^^this
  5. Sep 15, 2023 at 8:36 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    First manual transfercase I take it?
  6. Sep 15, 2023 at 8:37 AM
    I put bells on mine to remind me that the engine is running. :frustrated:
    kmeeg[QUOTED] likes this.
  7. Sep 15, 2023 at 8:37 AM
    :p:p:p:p
  8. Sep 15, 2023 at 1:04 PM
    Yup. Mine makes my gum container sound like a
  9. Sep 15, 2023 at 3:05 PM
    Here is a pic my transfer case and the shifter where it comes out the top. It’s just like a tractor. Except the entire drivetrain is mounted on soft cushy rubber mounts designed to flex a good amount. The amount of movement you see in that lever is exactly how much the trnsfer case, transmission, and engine are moving around on bumps and different torque loads.
  10. Sep 15, 2023 at 3:28 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    My old XJ didn't shake like the 4Runner's does.
  11. Sep 15, 2023 at 3:59 PM
    Looks like they have a joint and an extension because the case was further back than vs these go directly into the case.
    bassist[QUOTED] likes this.
  12. Sep 15, 2023 at 4:03 PM
    That can only mean the 4runner was completely and purposely designed around the shifter. They sat down the frame and drivetrain, and then built the body around it.
    It just shows how bad ass this vehicle is. :D
  13. Sep 15, 2023 at 4:23 PM
    bassist
    bassist New Member
    That means having a knob and a full length little space in front of the gearshift was NOT the original plan!
  14. Sep 15, 2023 at 4:57 PM
    The Runner is ok I guess.
    My aunt had a new fully loaded black 4wd XJ back in like 93. I think it had factory gold pin striping. We took it out once pulling some ATVs to who know where and from what I remember, it did really well.
    Those old 4wd XJs always remind me of the Jeep scene in The Goonies. “Throw her in 4wd and hold onto your hats!”
    https://youtu.be/Ge2ZPyOGCVk?si=PyUwf5cDtEUaoryv
  15. Sep 15, 2023 at 6:40 PM
    Good pictures thanks,
    What are those two pins sticking out at the top of the side that mate’s with the transmission?
  16. Sep 15, 2023 at 6:42 PM
    Those are the shift rails.
  17. Sep 15, 2023 at 6:46 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    This comment reminds me of the A-10 being designed around the Gatlin cannon. Amazing piece of engineering. Will be sad to see it go when it finally does
    2Toys likes this.
  18. Sep 15, 2023 at 6:49 PM
    frostytrd
    yes HAHA
  19. Sep 15, 2023 at 6:51 PM
    Ok thanks.
  20. Sep 15, 2023 at 7:25 PM
    Exactly. The first thing they made was the hole the cannon goes through. Same with the shifter.:p
  21. Sep 15, 2023 at 7:27 PM
    And here are the shifter rails on the inside with the shifter removed.
  22. Sep 16, 2023 at 8:30 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    It's cool to see cast parts.
